Question about Uniden BC92XLT Handheld Scanner
Program delete a channel
I want to delete channels on alba tv
press the menu then go to programming channel, select channel you want to delete.
Nov 25, 2012 | Televison & Video
How can I delete a channel already programmed in my Kenwood TK-705D?
You would need to use programming software and cables to make this happen.
Jul 09, 2012 | Kenwood Tk-705d Tk-705dh-1 Mobile Radio...
How to delete channels off a 32
Most but not all sets have in the menu where channels are programmed a feature to add or delete channels from the up down memory--this is done with the original remote--universal usually will not be able to do it.
Look for channel setup and then add/delete feature.
Apr 30, 2012 | Emerson Televison & Video
How do I delete channels off of my pro-135 handheld scanner?
To RESET the scanner and delete ALL programmed frequencies:
- Power the scanner OFF
- Press and hold the 2, 9, and PSE keys and power the scanner ON.
To delete a single frequency, program 0.0 into the channel - or program a new frequency into the channel (this will automatically override the old frequency).
Bill B.
Listening in since the 60's
Dec 07, 2010 | Radio Shack Pro-95 Handheld Scanner
How do i delete a frequency already programed? and can i get a frequency at 46.5000?
Programming a new frequency into a channel automatically deletes and replaces a frequency already programmed. Or, to just delete, and leave an unprogrammed channel, just program 000.000 into that channel
Yes, you can program/receive 46.5MHz. The full tuning range of your scanner is 25-54, 108-174, 406-512MHZ.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Nov 05, 2010 | Uniden BC72XLT Handheld Scanner
How do delete a frequency code from my scanner i know how to program but dont know how to take a frequency off thanks
Just program 0.0 (zero point zero) into a channel to clear the existing frequency. Also, programming a new frequency into a channel will overwrite/delete the previously programmed freq.
Bill B
Aug 02, 2010 | Uniden BCT8 Base Scanner
How do i clear all channels and start over putting in new ones
There is no global clear/erase function on the BC350C, but programming a new frequency on a channel automatically deletes/erases the old frequency. To delete an inactive or troublesome frequency, program "000.0" in that channel. Doing so will deleted the previously programmed frequency and set the LOCKOUT to ON for that channel. For more information on deleting frequencies, see page 27 of your operating manual.
Need the manual? You can download it here:
http://www.uniden.com/pdf/BC350Com.pdf
Sep 13, 2009 | Uniden BC350C Base Scanner
I need to reset the channels for my scanner
There is no global clear/erase function on the BC350C, but programming2_bing.gif a new frequency on a channel automatically deletes/erases the old frequency. To delete an inactive or troublesome frequency, program "000.0" in that channel. Doing so will deleted the previously programmed frequency and set the LOCKOUT to ON for that channel. For more information on deleting frequencies, see page 27 of your operating manual.
Jun 07, 2009 | Uniden BC350C Base Scanner
Channel programming.
This can be accomplished using a few steps. All sets allow you to delete channel. The first step is to autoprogram the set to receive all channels. Once that is complete, work your way through the menus to the channel selection portion. You should then have the option of deleting channels. Once you delete all the channels that are not wanted, the channel up/down should cycle through the remaining available channels. If there are channels that you wish to add later, the same menu should allow you to add them back in.
Dan
Apr 27, 2009 | Vizio VW32L 32 in. LCD HDTV
Uniden BC92XLT Handheld Scanner Logo
29 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
