Question about Beam Industries Vacuums
Fuse Lr88617 fuse
How do you get to the fuse in the dc28?
The 3-pin mains plug will have a plastic fuse holder which can be levered open with a small screwdriver. Look on the pin side of the plug. There will also be small writing on the plug to tell you which size of fuse is fitted to the plug. Replace with the same size of fuse. It is important to note that the fuse in the mains plug is only likely to blow if there is an electrical issue inside the machine, so replacing the fuse may just result in the fuse blowing again. If this happens then the vacuum needs proper checking and repair. DO NOT try using a bigger fuse, as you may cause more damage to the vacuum, or cable overheating or risk of electric shock.
Jan 09, 2017 | Dyson DC28
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Mar 29, 2014 | Shop-Vac Corporation Bulldog 8 Gallon...
Line fuse replacement
There is no line fuse, the only fuse is in the wall plug ,this link is for the manual
http://hoover.com/file/604/
Apr 28, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Where is the fuse located in the microwave?The model is a Whirlpool MH6700XV1 made in Sept 89. It is a wall unit over the oven microwave.
Hi and welcome to FixYa,
There are acutally 2 fuses in this unit. The thermal fuse is item 3 and the regular fuse is item 7 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=238334
Both fuses are on the rear of the unit inside the back panel attached to the air guide (Item 5 above link)
Make sure the unit is powered off before changing any fuse. Most fuses fail due to a component failure. High Voltage Diode, Capacitor, Magnetron or an interlock switch. If you replace the fuse and hear a loud humming when you try to use it most likely the diode has failed. DO NOT do anything beyond the fuse without grounding the capacitor first. It will ruin your day if it is charged and you touch a wire terminal. Any testing is done at your own risk knowing the dangers of same.
Thanks for choosing FixYa,
Kelly
Sep 24, 2011 | Vacuums
Shredder does not power on
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Aug 10, 2011 | Vacuums
I have a Husqvarna Viking Designer sewing machine. The fuse blew in the machine and I am having trouble finding a replacement fuse. It is a T3.5/250v glass fuse. Please let me know where to find one. I...
That fuse will work no problem. There is no harm in trying it.
The machine probably requires about 2 amps or less under normal operation.
Being a 3.0 amp slow blow fuse, it will withstand short bursts of extra current when your machine gets temporarily overloaded.
Just make sure the machine is properly lubricated and runs freely. The fuse will definitely blow if your machine should get jammed or something like that.
I think I know where I can score some. Cost of postage only. :)
Email me if you like.
Subject: T3.5/250v glass fuse
faxmando@yahoo.com
May 31, 2011 | Vacuums
DOES A DISHWASHER HAVE A FUSE? i HAVE 2 EXACT SAME DW STOP WORKING IN THE SAME MANNER - THEY BOTH JUST STOPPED MID CYCLE
yes, there is a fuse at the fuse box...there is no internal fuse... if they are both on the same circuit, that may be why it popped the circuit breaker (fuse)
Dec 05, 2009 | Vacuums
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Feb 08, 2008 | Eureka 6831A Bagged Canister Vacuum
Vacuums Logo
29 people viewed this question
Top Beam Industries Vacuums Experts
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
