Question about Samsung HL-T5687S Television
Lines Picture Vertical
HAS PICTURE BUT VERTICAL LINES ACROSS HOLD SCREEN
    Top Expert:
  • Samsung Master
  • 74,106 Answers
It sounds that the T'Con board has the fault. Check the LVDS cable, that connect in between T'Con board and panel for any loose contact. Re-seat it once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
Posted on May 06, 2013
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 79 Answers
SOURCE: Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
Posted on May 22, 2009
  • 11 Answers
SOURCE: Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
Posted on Sep 13, 2009
Model DP46849
That does not sound good.
Can you see part of the image or only vertical lines?
Can you post a picture?
Aug 11, 2014 | Sanyo Televison & Video
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Lines across the top of the screen
Check Vertical output IC circuit for bad capacitor.............
also vertical power supply for bad cap....Last----replace IC...
Nov 20, 2007 | Philips 32PT6441/37 32" TV
Samsung HL-T5687S Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
