Luxor tv The stanby light keeps flashing and the tv wont turn on
My luxor tv wont turn on and the standby light is flashing
Power supply in the set is most likely here. If you are not able to look inside and or test voltages etc have a shop look at it and get an estimate for repair.
Dec 21, 2012 | Televison & Video
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
Luxor 42 inch lcd tv stanby light flashing and tv not working. Anyone got ideas why?
Good day!!!!
Kindly,count the blinks of your TV because some TV have error code by means of how many blinks..
thank you
Jan 10, 2012 | Televison & Video
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | Televison & Video
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv won't come on
red stanby light just flashes and the tv wont come on
Apr 26, 2008 | Samsung HCN436W 43" Rear Projection...
Televison & Video Logo
436 people viewed this question
Top Televison & Video Experts
