Question about Sharp R-1610 Microwave Oven
Door Removal Sharp Microwave Model R-1611
The door on my microwave is cracked near the top of the handle. I need to find a replacement and replace it with a new door. But first, I want to learn how to remove the old door. Is someone able to help? Thanks, Bill
  • Sharp Master
  • 9,098 Answers
HUH?! This problem may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
The service manual will tell you how this REALLY is done.
We have a very similar manual at our site at:
http://www.microwavedisplay.com/r1610_sm.pdf
I do NOT recommend removing the door from the hinges or removing the hinges from the microwave unless it's absolutely necessary.
If you do, you need to be sure you get it mounted back EXACTLY like it was, or you risk leakage.
Most door repairs can be effected by disassembling the door, as long as individual pieces are available.
To order Sharp parts, visit http://www.wehaveparts.com
Posted on Nov 26, 2007
  • William Miller
    William Miller Nov 26, 2007
    We're happy to help and we appreciate your thoughtful rating of our answer.
  • 5,911 Answers
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Posted on Aug 10, 2007
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Microwave fan starts when door is closed
Replace defective microswitch in door latch assembly.
Nov 21, 2017 | GE Spacemaker JVM1540 Microwave Oven
How do you take off a microwave door and put a new one on?
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 27, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Need new handle on door
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 46-114897-3.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Mar 12, 2010 | Sharp R-1750 Microwave Oven
SHARP MICROWAVE R-1611 MADE VERY LOUD POP NOISE. NOW IT WON'T HEAT
20 A fuse inside m/w is out. The problem could be with HV condenser, one of the door switches shorted, computer board, magnetron. Needs technician to take a look on it.
Dec 03, 2008 | Sharp R-1480 Microwave Oven
Over the range Microwave trouble
It is a door switch problem of some sort.  I have two Sharp R-1611 units that do the same thing.  The light and fan come on, but not the heat, thank goodness.
I am going to replace it since the plastic for the case and door is cracked in numerous places.  I have spent several hours researching microwaves online have not a single clue what to replace the Sharp with.  Seems like every vendor has very good units and very bad units.  I guess you just pay your money and take your chances.
Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Fan comes on when slight opening pressure is exerted on door handle.
The door frame and seal damage has put the relation of the door latches and the interlock assembly out of adjustment. If after disassembling the door it is found that the latch assembly is good, replacement of the door frame/seal might be all that is required to return the oven to normal operation. After reassembly, it is highly recommended to have the oven's emissions checked at an authorized service center for any leakage around the door seal area. The service center might also need to adjust and set the interlock assembly for correct operation also.
Oct 31, 2007 | Sharp R-1610 Microwave Oven
Sharp R-1610 Microwave Oven Logo
376 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
