Question about Nikon COOLPIX L820 Digital Camera Red 26403 Norman Camera
Camera Battery door open while camera in use
  • dj_wininger Jun 02, 2017
    Check the little latch for a broken hook. May need to replace the battery door.
    New Friend:
  • 49 Answers
The problem of the gripper
Posted on May 05, 2013
Testimonial: "Am I the gripper and what should I do differently"
Removing battery
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Mar 20, 2014 | Nikon COOLPIX L6 Compact Digital Camera...
My nicon s2500 camera automatic on when i install my battery.
This is not a normal way of switching on a camera, because most cameras have a door switch, that indicates if the battery door is open or closed. If the battery door is open you should not be able to switch on the camera. If some dirt cam between the housing and the door lock switch or some other mechanical failure took place, that could cause this strange phenomena. Please remove the battery again, check if the battery door can move free and nothing is in or around the edge. Then reinsert the battery and close the door. If the error keeps coming back, please visit your dealer of contact the nearest Nikon service centre.
Jan 09, 2014 | Nikon Cameras
How do I open the battery door
Open the battery door of what make and model camera?
Jun 07, 2013 | Computers & Internet
How do I open the card/battery door on my Powershot A570 Camera?
My canon camera does the same thing. Engage the button and use your fingernail to wedge between the battery door and the camera body. This should cause the door to slide open.
Jun 24, 2012 | Canon PowerShot A570 IS Digital Camera
How do i open the battery door on my D3000
Try again. Slide the tab and pull on the door lightly. Or after sliding it, keep the slider in that position and turn the camera upright so that the battery presses against the door.
May 16, 2012 | Nikon D3000 Digital Camera
How do you get the battery door open on the sharper image u-video camera?
The battery door is at the bottom of the camera, just below the little box with THE SHARPER IMAGE in it and opens easily ...if you know the trick. (The tripod mount is in the bottom of the door.) using your thumb, press down on the tripod screw hole and push on the door from the front of the camera toward the rear and the door pops open. Reverse the procedure to close.
Dec 25, 2010 | Cameras
I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Sep 04, 2009 | Canon Sure Shot 70 Zoom Date 35mm Point...
My olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING....  battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
Jun 17, 2009 | Olympus FE-330 Digital Camera
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Nikon COOLPIX L820 Digital Camera Red 26403 Norman Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
