Question about Garden
Toro lx 420
I have a toro lx 420. It will not hold a charge. I bought a new battery, no luck. I tested the battery and it is fine but it is getting power at all. P.S. the tractor was running and I lowered the deck when it died ( mower was not engaged, I just lowered the deck)and it died, now gauges don't work and it is as if there was no battery at all. I can not see where the deck may have pinched a wire. All wires seem to be in place and not even close to the deck system.
SOURCE: the mower is not charging the battery
Have someone with an amp. meter check across the battery terminals with the engine revved to max speed. It should read 13.5 or more volts.If it is reading that much or more then you should suspect a bad battery. If you had a bad charging coil you would not much on the amp. meter. donnyb60
Posted on Mar 23, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
wireguy212
  • 1627 Answers
SOURCE: 1998 John Deere 325 belly mower 48" deck will not stay engaged.
There is a safety switch on the diferential that lets the tractor know that your not backing up that is likely defective,unplug it until you can get one in to replace it and you should be good to go.It's on th right side mid housing on the hyrostatic unit[rear diff].
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: I have an LX178 tractor
The clutch is engaging, but it cannot turn the pulley, so the engine bogs down....
No, I don't think it is a clutch problem... it sounds more like you have a bering out on one of the mower deck blades, or the belt has jumped off and is pinched... at any rate the belt is not able to turn so it bogs the engine down...
To find the problem, you will probably need to remove the mower deck, then take the cover off over the belt and then check out all of the blade and idler pulleys to make sure that they all turn easily...you will find one that is frozen up....
BTW... you should be able to spin the belt...with the engine off....grab the belt and check it out....
heatman101
Posted on Sep 04, 2011
  • 6468 Answers
SOURCE: pto, electric clutch
check the wires they rub on sharp edges
Posted on Mar 24, 2012
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
May 02, 2016 | Toro Riding Mower LX Series 22 HP Kohler...
Does the hour meter in a toro tractor lx 420 show Tenths?
Best way to check that out is to run it for six or seven minutes and see it the number changes by .1 and if it takes an hour of running to move the nkmber you will know that it reads hours nit tenths.
Sep 21, 2014 | Garden
Toro lx 420 wont start, sounds like starter wont engage jst a clicking sound. I put a new battery and solenoid in and still the same
starter motor i would suspect. try hitting it with a hammer to jar it into life. im sure its the starter motor.you could try running a positive from the battery to the positive on the starter motor to see if it turns if it does not replace srtmotor
Mar 08, 2014 | Vertex Ride On Mower
I have a Toro LX 420. Bought in 2006. Put a new battery in and I get a click sound under the seat where the battery and solenoid are when I turn the key. Is it the solenoid or the starter?
Most likely it is the solenoid especially if the battery is new but the only sure way to tell is to test the battery with a volt meter for 12 volts or more or use a HEAVY jumper wire and cross the two large posts on the solenoid. If it cranks when you cross them, replace the solenoid. don't hold the wire on too long, it will get hot and melt the insulation
Sep 24, 2009 | Garden
Battery Spec
No thats fine as long as its 12v it will be fine you will just have a little more reserved power for start up. Good luck and thanks for using FIX YA
Mar 03, 2009 | 1994 Mazda 323
Two new batteries, won't hold charge
I would Check the Belt Tensioner. If the Belt Tensioner is Not Holding the Belt Tight Enough it will not allow the Alternator to Charge the Battery and will result in the Dead Batteries. Please Rate My Response! Thanks!
Feb 07, 2009 | 1991 Honda Accord
Battery won't hold a charge after sitting for a while
First tell your husband to by a test light! They last for ever! LOL
The prob is most likely the alternator. Remove the negative battery cable, then the power cable at the alternator. With his 'new' test light, check for power between the negative battery post and the cable removed from the alternator. If the light comes on, the alternator has a diode prob. If you want you can also take it for a drive, then remove the battery cable, let everything cool over night, reconnect the cable, wait for about half an hour, feel the alternator for warmth. Frankster016
Nov 28, 2008 | 1995 Ford Windstar
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
