F-80 went to print and the printhead will not move.
Belt is tight and can move printhead by hand with no obstruction but when I press RESUME the printer goes through the motions but when it is time for the printhead to move there is a quick clicking sound like the belt is slipping on the motor spindle. THe printer has been having spells where the printhead would not return to the parked position but I was always able to manually push it into position, unplug the printer and it would fireup and reset the printhead and then everything worked fine until the next time. I like the printer and prefer to fix if possible. Especially since the new printers all have the new non refillable ink tanks.
Re: F-80 went to print and the printhead will not move.
If you have had it a time then the belts can get worn so can dust and excess ink build up if its new try one of 2 things ...you can remove belt place it in hot water then straight into cold frocing the belt strech but stop when it hits cold water the second thing you can do is loosen the belt track..cheap trick
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
Open the access door.
Disconnect the power adapter from the back of the printer.
CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
Close the access door.
Connect the power adapter to the printer.
Remove the ink cartridges from the printhead.
Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
firmly until you hear it click into position.
Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
Here are some steps that can help you resolve yoour issue.
Make sure that we use a genuine HP ink cartridge
Try printing a diagnostic page from the control panel. Here are the steps:
Press and hold the Power button Press the Cancel button for seven times Press the Resume button for 2 times Release the Power button
If the issue persist
Try Cleaning the printheads. Here are the steps:
Make sure there's unused paper Press and hold the Power button Press the Cancel button 2 times Press the Resume button 1 time Release the Power button
If still the problem persist try reseating the cartridge Open the cover Make sure paper is loaded in the Tray If the carriage does not move to the left automatically, press and hold the Resume button until the carriage moves to the left. Wait for the carriage to stop moving. Lift the printhead latch Lift the handle of a printhead, and use it to pull the printhead out of its slot Before installing a new printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Remove the new printhead from its package, and then remove its orange protective caps, Do not shake printheads after the caps are removed Insert the printhead into its color-coded slot. Press down firmly on the printhead to ensure proper contact Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Close the cover, wait while the device initializes the printheads and prints the alignment pages
If the problem persiste contact HP support for service.
Materials needed:
New empty syringe (big one)
Gloves (to protect your hands fromink)
Alcohol
Paper tissue (to clean the excessink)
Empty Plastic bottle (Here you putthe ink from the syringe)
Important:
Ensure that you have put new blackink cartridge to K8600.
Ensure that the printhead arerecognized by the printer or no light alarms.
Instruction:
Press the Power button to turn onthe printer.
Test print in microsoft excel with4 color black/yellow and cyan/magenta.
If black only is missing means youhave clogged problem from the host.
Wear your globes, prepare thematerials needed.
Open the top cover.
Press and hold the Resume buttonuntil the carriage moves to the left.
CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation.
Lift the printhead latch.
Lift the handle of a printhead anduse it to pull the printhead black/yellow out of its slot. Put printhead in thepaper tissue upward.
Your printer are still ON becarefull not to touch the flex copper circuit.
Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture)
After the done the syringe method,Insert the printhead black/yellow into its color-coded slot.
Press down firmly on the printheaduntil it snaps into place.
Pull the printhead latch all theway forward, and then press down until the latch engages.
Close the cover.
The printer should align theprintheads automatically in a few minutes, printing an alignment page.
Print a test with black color only,If it does not print, try to change the Printhead.
This is the only solution I foundin my HP k8600 black ink problem.
Materials needed:
Alcohol
Important:
Ensure that you have put new Magentaink cartridge to HP K8600.
Instruction:
If magenta only is missing means youhave clogged problem from the host.
Open the top cover.
Lift the handle of a printhead anduse it to pull the printhead magenta/cyan out of its slot. Put printhead in thepaper tissue upward.
After the done the syringe method,Insert the printhead magenta/cyan into its color-coded slot.
Close the cover.
Print a test with magenta coloronly, If it does not print, try to change the Printhead.
This is the only solution I foundin my HP k8600 printing problem.
dear,
Error 5100 points to a "carriage jam" The carriage is the assembly that contains the printhead and cartridges. This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage. Verify that the carts and printhead are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've never done it before. If this does not work, unplug, wait 3-4 min, then re-plug in. Enjoy..
This will either be a problem with the printhead drive motor, the ribbon cable going to the printhead, or even worse...a problem with the circuit boards inside the printer. It will need to go into the shop for repair.
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once. 1. Start with printer OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4. press RESUME twice, then release POWER 5. let green light blink until printhead has finished moving. 6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960) 1 press - orange light - EEPROM info print 2 presses - green light - EEPROM initialise 3 presses - orange light - reset waste ink counter.
goodluck hope it works
I FOUND A SOLUTION that worked for me for the CANON F50:
F30/F50 Printer
1. Enter Service Mode - by pressing "menu then copy then #"
2. Select TEST MODE
3. Select (8) PRINTER TEST in TEST MODE
4. Select 3 (EEPROM CLEAR)
5. Select 0 (INK COUNT)
6. Press Stop/Reset key
7. Press On/Off Key
try to move the printhead left to right. and make sure there is nothing obstructing it. Also make sure you ink cartridges are in securely. If that doesnt work let me know.
