Question about Viore 37" Class LCD 1080p 60Hz HDTV, LC37VF60CN
My tv turn off every 4 minutes
I turn on my Viore 37" 1080. But it turn off in about 4 minutes. I turn on againt, but it turn off. I check the sleep timer, but its turn off.
    Top Expert:
  • Viore Master
  • 74,251 Answers
There should be some loose solder terminals at the main power regulator board to your TV.
Posted on May 06, 2013
Viore 42 inch tv PD42Vh80 had no sound but great picture HDTV
speakers switched off?
volume on set or a box down or muted? check both the set and box.
Does the set have normal sound when playing a DVD etc via the audio and video jacks on the rear or side?
Apr 29, 2012 | Toymax Viore 42 in. Plasma TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
What happen when trun on a tv but it go off by itself (viore tv)
First check to see if you have a sleep timer set in the menu. Some flat panel units also shut off if the do not detect a signal.
Aug 16, 2010 | Televison & Video
My viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
Jul 24, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore tv turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Mar 30, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
What is the code for cable remote
Viore told me that they do not have a code that can be input into any remote. I have two Viore TV's... just bought my 2nd a few days ago. You will always have to use the Viore remote to power up or just turn off the cable instead. Not sure that turning off cable completely turns off the TV though.
Jul 31, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
Viore 37" Class LCD 1080p 60Hz HDTV, LC37VF60CN Logo
166 people viewed this question
Top Viore Televison & Video Experts
Tom Chichester
Sp Gupta
D. E. Hev
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
