Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
Toro timecutter starter
Starter seems to spin and does not engage the engine
  • 3,105 Answers
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
Posted on May 06, 2013
  • 17102 Answers
SOURCE: I have a Toro Z14-38
There is very little likelyhood that you will be able to get the manual that you want.
First TORO has proprietary information on their products.
Second is the fact that you are agreeing to only pay 4 dollars for something like that.
The only other thing that you can do is look in the US patents database to see what you can find.
Posted on Nov 27, 2010
2strokeJim
  • 577 Answers
SOURCE: toro timecutter z4220. i just
release the park brake and try that,brake has to be engaged to start
Posted on Aug 07, 2011
  • 6468 Answers
SOURCE: problem with Toro self starter
remove the cover and look for a missing tooth on one of the gears
Posted on Mar 27, 2012
  • 747 Answers
SOURCE: Toro Z4200 Kohler engine. I was mowing and shut the mower down. When I tried to restart it would not start, not even a single fire. Starter works fine.
check for spark is the wire on the spark plug is the plug good check for fuel flow possible electrical short
Posted on Jul 07, 2012
  • 4 Answers
SOURCE: Toro groundsmaster 120 engine kills when engaging blades at switc. Clutch? clutchWhat's your problem?
unplug wire form temp sensor on right side of engine and then try to engage pto
Posted on Nov 09, 2012
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
How do i install a starter cylonoide on a toro timecutter rear engine lawn mower that has a kawasaki 22 hp motor i dont know were the green and blue wires go
do you mean a solenoid? if so then the 2 wires fix to the spade terminals on the solenoid just below where the 2 large red ires are bolted to the solenoid
May 06, 2015 | Toro Garden
Behind starter fly wheel only moves back not forward wil not start not start starter seems like its working spins
Disconnect the battery and then carefully remove the starter. Take the unit to a local auto parts dealer for a bench test. Starters have two separate functions, one spins the shaft to crank the engine, the other is called a bendix, which pushes the starter gear out to engage the flywheel, and then after the engine engages, retracts it (except in the case of starter/generator combo units which recharge your battery and power your vehicle's electricals while the engine is running) Always best to get a bench test rather than depending on apparent symptoms.
May 03, 2015 | Polaris 2009 Sportsman 850 EFI XP With EPS
I have a toro timecutter ss5000 and the battery will not stay charged. I bought a new battery same problem. What actually charges the battery the solenoid?
Actually is the alternator on the engine thru a voltage regulator and 25A fuse then thru the ignition switch to the starter solenoid and on to the battery..
Mar 23, 2015 | Toro Garden
How to remove starter on Toro Z master with kohler 26 HP engine?
First disconnect the battery. Then unhook the wires from the starter should be one or two wires. Remove the bolts from the starter two or three bolts.
Jul 24, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
298 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
