Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
With Kawasaki engine, the starter motor spins, does not engage
    Problem Solver:
  • 4 Answers
The way them starters work is it is either engaged by a silonoid or a reverse plastic gear so when the starter is energized the gear comes up so. In other words u can buy a new starter or take it to a shop and have them rebuild it. If it is the plastic gear kind u can geta new gear for it
Posted on May 07, 2013
2 Suggested Answers
  • 6468 Answers
SOURCE: problem with Toro self starter
remove the cover and look for a missing tooth on one of the gears
Posted on Mar 27, 2012
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
Kawasaki bayou 300 starter spins but wont engage all the time
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
Mar 21, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
92 honda civic hatchback new starter spins does not engage flywheel, could it be a fuse
unlikely as the motor spins. It appears that the motore solenoid is allowing the motor to spin before engaging the teeth in the ring gear. ON a lot of starters the pivot pin is adjustable to allow for correct engagement.Remove the starter and check that the solenoid is fact connected to the clutch part of the starter. Check that you have the correct starter for the engine
Jan 19, 2013 | 1992 Honda Civic
Starter motor whines but wont engage with engine on my rover P2
You will need a new starter rebuilt ect. to replace the one you currently have that is defective. you sound like you are spinning the starter motor but the starter bendix is no longer engaging the flexplate/flywheel on the engine.
Sep 10, 2012 | 1938 Rover P2
Starter made a grinding sound in motor and now just spins free
You need to remove the starter & replace the bendix drive. The bendix is what engages the starter gear to the engine.
murf427
Aug 01, 2012 | 2005 kawasaki Ninja 250 R
Bike would not start.
If you are hearing the clicking sound that means that your starter motor's relay is trying to engage. Probably you don't have enough juice in your battery. Charge your battery very good and give it a try again.If still nothing happens then you must take out the starter motor and have it repaired. That spinning sound also suggests to take a closer look to your starter motor and your starter clutch which is located behind the stator's rotor.
Feb 03, 2012 | 2007 kawasaki Vulcan 900 Classic
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
204 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
