Hp 4215 printer paper won't feed
  • 5 Answers
SOURCE: hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Posted on May 08, 2009
SOURCE: won't feed paper
I had the same problem it was not feeding paper, and was giving the out of paper msg, I checked and the feed roller ( small black one in contact with paper) was not rotating, Also when the back cover is removed the roller also did not rotate. I took apart the printer and found that a white gear with the encoder disc (clear film with printed lines) on the central shaft was slighty broken, The shaft is knurled but is a poor design. I had to drill through the gear and the shaft to fit a pin to be able to fully secure the gear to the shaft. Kevin
Posted on Jun 09, 2009
anjana03
  • 361 Answers
SOURCE: 'Paper jam" on hp 4215 all in one while there is no paper jam
ithink it is not softwere pfoblem. it is related to the sencer which is connectet to the paper feder ...etc and some time dust of printer created that type problem . in our gener al practes we solved this problem. first we should open cover and drum then blow air by blower. in this way we remove disattach ment of senser., then printer can work.
Posted on Jun 18, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
  • 7 Answers
SOURCE: paper won't feed properly and
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
Posted on May 06, 2011
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
Hp 4215 false paper jam
Click on this link below and it will show you (with pictures) step by step instructions on how to clear a paper jam with the HP 4215 All In One printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00097153&lc=en&dlc=en&cc=us&product=351106
Dec 01, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Jun 18, 2009 | HP OfficeJet 4215 All-In-One InkJet...
While copying on 4215 HP officejet printer, it has stopped
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper will not feed into officejet 4215 to fax or copy, it stalls in the feeder.
Sometimes the feed rollers can get dusty or acquire other deposits on them that can cause a loss of friction, resulting in feed problems. You could try cleaning them to see if it would help. Here's the instructions:
Cleaning the Rollers
Post back your results and good luck.
Oct 10, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Officejet 4215 not printing
It could be an empty/dried up cartridge depending on how old it is. If the printer just feed the paper straight through without trying to print(i.e. the printing head is not moving), then it is most likely a configuration problem.
Sep 10, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Download
my hp 4215 all inone printer is not taking paper
Apr 14, 2008 | HP OfficeJet 4215 All-In-One InkJet...
jasbo
jasbo
