Question about Dryers
Amana NED4500VQ2 Will not heat
  • Dryers Master
  • 2,950 Answers
Probable causes, by most common to least common are:
1) Heating element ( a coil of special wire inside a heating box) has broken, needs replacement.
2) One of the overheat sensors has "tripped" and needs replacement. ( There are from 2 to 6. )
3) A wire has burned in two, needs repaired ( usually near the heating element).
4) A wire has burned or broken where the cord attaches to the back of the machine. Needs repair.
5) A circuit breaker has tripped in your fuse box, wherever that is. (In your hall, garage, basement, or wherever) Needs reset.
Be blessed.
Posted on May 06, 2013
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
Setting Amana Heat Pump Thermostat.
The 2H/1C is one stage cooling two heating. Is it s touch screen or not. I mean no buttons. If not go to mode setting. Push mode till you get to heat not emerency heat abd then set temp. Keep in touch. Rus
Nov 19, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
My AMANA electric drier will not heat
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
Feb 22, 2009 | Amana NDE2335AY Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dryers Logo
76 people viewed this question
Top Dryers Experts
