Question about Samsung LN32C540F2D 32 LCD TV
Tv will not turn on. pressing the "up" button on the remote sets red flashing led 3 times repeatedly. sure this is a code of some sort just not sure how to remedy. please help
SOURCE: Remote not working
I have the same TV, and it has developed exactly the same problem! Hopefully there is a solution...
Posted on Sep 23, 2007
CAYPIANAN
  • 227 Answers
SOURCE: Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Posted on Nov 08, 2008
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
  • 119 Answers
SOURCE: My tv wont turn on when i press the button, the
The capacitors in the power supply are bad. Take the back off, look at the capacitors, "barrels", if the top is bulging up, they are bad. Caps are around $2 each at radio shack x 6?
Posted on Feb 25, 2011
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
I forgot the code of my chunghop universal remote RM - 133 E my tv is JVC
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then do these procedures
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
1. PRESS and HOLD the SETUP button until the red LED flashes twice.
2. PRESS 9 - 7 - 5, the red LED will flash twice.
3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
4. PRESS the button that will receive the learned function, the LED will flash rapidly.
5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through
6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Feb 15, 2011 | RCA Universal Remote Control
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a jumbo universal remote,how do I programit to an rca tv?
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Nov 23, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
  1. Turn on your TV.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
specific device.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
I need codes
specific device.
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn of I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 26, 2009 | RCA DIRECTV Satellite Remote Control
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Samsung LN32C540F2D 32 LCD TV Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
