Question about HP USB OPTICAL MOBILE MOUSE
Optical mouse repair
When ever I connect my mouse it works perfectly fine...for several seconds! I have tried updating the drivers, scanning my computer for viruses, restarting my computer and reconnecting the mouse etc. I am a PC gamer so this is a HUGE problem for me , please please please please give me a solution that will work.
    Problem Solver:
  • 9 Answers
There is proabaly a short in the cord you might need a new one.
Posted on Oct 29, 2013
4 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: hp wireless mouse model #m971au pointer stopped working
Make sure your batteries are good and then, Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Posted on Jan 16, 2009
  • 1602 Answers
SOURCE: Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Posted on Feb 09, 2009
Lanijo58
  • 73 Answers
SOURCE: I just bought my mouse
Sometimes if you have the optical mouse on Black pads, that can be a problem. Sounds as you have the battery in right, Have you tried rolling the wheel, to make sure it isn't out of sight? Now if you had to install software for the mouse. Take out the receiver, (USB part) then uninstall the software. Then restart your computer, then if you have the software, run it, I wouldn't put the USB part in until it tells you to, then leave it , you may also want to try a different USB port this time. Reinstall follow directions, it should work. Hope this will help you,
Posted on Jun 02, 2011
Using Windows 7 - My USB logitech M-BJ58 mouse keeps disconnecting/reconnecting. It works fine on my old XP system. I've tried different USB ports, but I'll be working fine then heard the USB disconnect...
I am thinking you may have to do a system restore to before you got the update. Did you update the drivers for the mouse for Windows 7? Sometimes the older OS drivers get buggy on Win 7. You can get the drivers for free from Logitech's website. One other thing to check, make sure the USB connector is not worn, sloppy or has a broken wire under the rubber cover. It can happen. You should be able to remove the last Win update then you will know if that is the culprit. Hope that helps.
Aug 06, 2013 | Logitech M-Bj58 OPTICAL WHEEL MOUSE...
Mouse right click doesn't work ie8
does it work with other browsers ? try updates and run cc cleaner and run a registry scan too also restart the computer several times
Apr 27, 2010 | Microsoft Wireless Optical Mouse
M trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like. much thanks!
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
Apr 10, 2010 | Generic Memory Mini Retractable USB...
My mouse on my dell latitude d600 will wonder into a corner and not come out for several seconds
try connecting an external mouse. if no problems using external mouse then uninstall reinstall the touchpad driver. you can get the drivers from the dell support site under drivers and downloads.
if problem persist even using an external mouse then try to (update anti virus and run full system scan, uninstall any previously installed windows updates or do a system restore) update the BIOS as well.
Oct 21, 2009 | Dell Latitude D600 Notebook
Can't control mouse
you may want to check the cord od your mouse for possible breaks. if the cord is okay, change the port if it is a USB mouse. If it is not an optical mouse, then you may want to open it and clean the rollers that the ball under the mouse touches.
Jun 01, 2009 | Macally iceMouse USB Optical Internet...
Mouse Not Working in XP
the very first thing what u have to do is uninstall and reinstall the driver for the wireless mouse and then restart the computer and still if it doesnt work try it with some other computer which has xp sp3 and it it works with the other computer have the same windows os then uninstall and reinstall the wireless driver also,and if it doesnt work with the other computer also then replace the wireless mouse.but before that always check ur wireless connection with the wireles mouse and also check the lights on the mouse..and what u can do is call up dell and tell thatm to replace it for u or for complete solution u can call up cyyberdefender.com for premium tech support.......take care ...
Jan 23, 2009 | Microsoft Wireless Optical Mouse
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Optical Mouse Not Connecting
when do resetting chk whether u are getting blinking light on mouse. if yes and after resetting the light is steady then ur mouse if fine. if u are using vista then use the os disk go to the os installation screen and chk whether the mouse is active there. if yes then reinstall drivers or update it.
Sep 21, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless mouse quits working after a few seconds
Did you replace the batteries? This sounds like it may be the problem. A year is a lomg time for batteries depending on how often you use the computer.
After changing the batteries, you may have to do this:
Sep 03, 2006 | Dell Wireless Keyboard Optical Mouse w0147
HP USB OPTICAL MOBILE MOUSE Logo
53 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
