Question about GE Advantium 120 Convection/Microwave Oven
Microwave section not working
Microwave (speedcook and full-function microwave) stopped working, but light comes on and turntable rotates. Control panel is fully functional. Any thoughts on what this might be? This is model SCA1000DCC.
  • Anonymous Nov 12, 2007
    Microwave makes sound, turntable operates, oven works, but microwave does not work/heat.
  • GE Master
  • 9,098 Answers
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions.
Posted on Sep 28, 2007
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
My samsung SMH1611B Microwave Oven does not heat
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Please reply back with your brand and full model number from the tag so we can help you properly.
Mar 02, 2013 | Samsung SMH1611W Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
The microwave facility in this multi function Sanyo shower wave oven EM-D993 has ceased to work. Everything else does.
When you hit Start to cook, do the inside light and turntable come on?
Nov 24, 2008 | Sanyo Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
80 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
