Question about Garden
Where can I purchase a clutch cable for an earthquake badger 3365
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Cs4518 earthquake clutch tool
I usually try to make my own tools for these situations - do you have any skills/abilities for that? Otherwise try another dealer, negotiate a loan of the tool maybe. Many special tools eventually make it into the aftermarket, possibly they are being sold online somewhere.
Apr 01, 2014 | Ardisam Earthquake - CS4518 - Chainsaw
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
How do I change the blade on a 3365 planer
Page 7 of this manual describes how to replace blades:
https://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D//t10/0000000/r00143v-1.pdf
Feb 21, 2011 | Bosch 3365 5amp Planer
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
