Question about Garden
Echo gt-200r not starting good plug.
Dad had used it til the gas ran out and he put another tank in it went to start it and wouldn't crank acrs like its not getting fire but i checked it and everything checked out to be fine?
    New Friend:
  • 3 Answers
Check spark plug and make sure it is firing- pull the plug - ground it and pull start cord and see if the plug is firing.call me at 901-454-7772 if you want me to tell the other stuff you can do. Bill Robinson
Posted on May 14, 2013
panilling9
  • 284 Answers
SOURCE: My Echo GT-200R will not start.
you need to make sure your plug is sparking
and if it is wet then the engine is flooded with fuel
press your primer bulb 5 or 6 times and use no choke and hold throttle open when trying to start it
Posted on May 26, 2009
If you have not had a solution by now (I know it's been a month since your post...), I just read on another help site that by cleaning the exhaust port would solve the problem. That port gets gunked up and the motor won't work if it can't "exhale" correctly. Good luck.
Posted on Jun 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: engine starts finem, but will not reach fill RPM.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
canbruce75
  • 1776 Answers
SOURCE: echo gt 2000 wont start
Mix the fuel/oil ratio an ounce of two cycle oil to a quart of gasoline or 4oz of two cycle oil per gallon of gasoline. I don't think that the fuel mix is the problem though. Check the screen at the exhaust port and clean out any carbon build-up found there. I would clean or replace the in-tank fuel filter as well. Anyway, hope this helped and best wishes.
Posted on Aug 18, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Primer bulb stays in after depressing it.
sounds as though fuel lines are incorrectly hooked up
Posted on Sep 18, 2009
Testimonial: "Echo GT 200R Grass Trimmer.Fuel lines were correct.I had purge base gaskets on wrong side of carb.I replaced gaskets but still won't start.Carb cleane"
Echo gt 200r
If little peaces getting carb. YES
Mar 23, 2014 | Garden
2010 dodge avenger 2.4L motor seemed like I ran out of gas and stalled wouldn't start so I poured gas til it was full then everytime I try to start it it smells like gas n has a hard time starting
Camshaft position sensor. It needs to know which cylinder is needing fuel, so it can fire the injectors at the correct time. It must have failed you. It should not be too difficult to replace or very expensive.
Dec 17, 2017 | 2010 Dodge Avenger
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
THE OTHER DAY COMMING HOME FROM WORK MY CAR DIDN'T WANT TO GO. THE MORE I PUSHED THE GAS PEDAL THE LESS POWER I HAD. IT SOUNDED LIKE IT WAS BOGGING OUT OR SOMETHING. PUT MORE GAS IN IT. THOUGHT...
change your fuel filter seeing that you may have ran the tank right down it may be cloged it may me a good idea to service the hold fuel system, injectors, throttle body, lines, tank,filter.
Jul 27, 2011 | 1997 Chevrolet Cavalier
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My Echo GT-200R will not start. The plug is clean and wet. The switch is "On". Fuel (50:1) is new. It was working 2 weeks ago. Thanks, Chuck My echo gt-200r will start and idle but any time you push...
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
May 29, 2009 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
