Question about Goodman Heating & Cooling
Broken motor mount
One of the motor mounts on my ARUF032-00A-1B Goodman air handler are broken. Is there a fix or do I need to replace?
    Genius:
  • Goodman Master
  • 1,363 Answers
They make a band mount to replace it with.
Posted on Aug 14, 2015
Joe_Rex
  • 114 Answers
SOURCE: GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Posted on Apr 28, 2007
  • 230 Answers
SOURCE: Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Posted on Jun 10, 2008
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
meBNme
  • 334 Answers
SOURCE: Goodman Air Handler motor will not turn off.
Look at your Thermostat wiring.
If there is a green wire going to the "G" terminal, disconnect it.
If it stops running, you have a bad T-stat.
If it keeps running, you either have a stuck fan relay or a low voltage control wiring malfunction.
Those are usually related to one of the safety switches having problems.
If green is not going to G, let me know, and we will determine which one is indeed the fan wire and go from there.
Remember, when you rate the solution, it closes further dialog, so only rate when you are satisfied with the discusion.
Thanks for visiting FIXYA!
Posted on Jan 03, 2009
james3751
  • 614 Answers
SOURCE: MY GOODMAN AIR HANDLER IS DRIPPING WATER FROM THE
You may have dirty stopped up drain pan or drain. Take a dryvac and **** the drain from outside. This will clear all the drain. Is it cooling ok? Is the unit in an attic? The drain is not hard to clean. Check your coil(evap) inside to see if this is clean. Rus
Posted on Jul 11, 2009
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
How do I clean the coil?
there is no clen way to do it. you have to access the coil from return air side. remove air-filter & spray coil cleaner on surface of coil then rinse. i would take a fin comb first and get as much surface lint and dirt as possible.
May 20, 2014 | Goodman AWUF180516 Vertical Wall Mount,...
What can I replace my goodman CK36-1B with to be compatible
you need a 5/45 x 370 volt mfd capacitor. I just installed one in the same type of AC today. 5 mfd is for the fan moter and 45 mfd is for the compressor, the 370 is the voltage.
Jul 29, 2012 | Goodman Heating & Cooling
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
I have a Goodman AR36-1 air handler. when I turn on the AC or the heat the air handler motor comes on for about a minute or two and then shuts off. The heat pump continues running and I can hear the air...
Hello Your motor is shutting of thermal overload because of an internal problem.New motor time,Pull it and match it up the info is on the side of the motor.
Oct 05, 2010 | Goodman Heating & Cooling
Where can I download Goodman ck49-1b owners/maintenance manual
i looked on the goodman dealer info finder and nothing came up with the numbers that u provided. the unit should have a model number product number and serial number. call goodman in reno 17753581188 give them as much info as you can with the numbers and they should be able to fax or email the info to you. www.goodmanmfg.com you might be able to find homeowner literature however i can look this up through the dealer site but like i said your numbers did not give me any matches sorry.
May 31, 2009 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
