Question about Panasonic TCP50S1 50 in. Plasma HDTV
Green line screen - Panasonic TCP50S1 50 in. Plasma HDTV
    Top Expert:
  • Panasonic Master
  • 74,383 Answers
The green line wit plasma displays denote a fault to its panel. But before confirming it, a proper check should be done. Check the site lined below. There are screen shots to defective plasma displays. Pull up older posts there. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. http://electronicshelponline.blogspot.com/
Posted on May 06, 2013
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
I can see a green line on my mac book pro screen
First, reboot the computer and see if it still comes up after that.
If the green line persists, plug your macbook into another display- does the green line show up there as well? If it does, the problem is with the graphics unit. If not, it's a screen issue.
Sep 25, 2012 | Apple Computers & Internet
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
Panasonic TCP50S1 50 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
