Question about Simplicity ZT4000 26 / 48
Engine dies in reverse.
I have a ZT 4000 Simplicity 26hp/48in deck that only has 150hrs and it now dies whenever I put it in reverse? It starts fines idles and runs forward at full speed but when I put it in reverse it dies. What could be the cause of this?
2 Suggested Answers
  • 152 Answers
SOURCE: i have a simplicity tractor with gas 27 hp, 60 deck. needs work but i can't move it. with engine off by hand i can push it forward but will not move in reverse.
There is a transmission release level on the back of the tractor. Pull that out and you should be good to roll.
Posted on Aug 21, 2016
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Car dies when put into reverse
Is it possible the engine block is shifting in reverse and something in the wiring harness or a vac hose is being affected ?
Jun 13, 2013 | 1996 Buick Century
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
My dad is trying to fix a lawn mower for a friend. It is a John Deere LX172. Whenever the mower deck is engaged or the unit is put into gear, the engine dies as if the ignition were shut off. I think...
Check the seat switch. That will cause your problem. It happened to me when I was not sitting on seat and turned deck on. Mine is a LX172 also.
Aug 12, 2011 | Garden
Mod# 917289450 54" deck
Next time as the engine begins to stall, loosen the fuel cap.
If the engine runs smoothly, clean the vent holes on the gas cap.
Gary
May 04, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Briggs & stratton 26HP engine is reving up and down after 30 min
I removed the engine and broke it all down last night. Inside the engine I found a mole. Once I removed the live mole and cleaned the valves - it worked fine.
May 13, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
98 Ford Taurus shuts off when shifted into gear.
its in the timing ...whenever you start it it sits and idles fine but when you go to put it in gear it dies...the timing needs to be repaired. its a guaranteed solution.
Feb 13, 2009 | 1998 Ford Taurus
Simplicity ZT4000 26 / 48 Logo
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
Will Mishler
Will Mishler
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
