Question about Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery
I press the run button and motor spins for a second then stops. It repeats this action.
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
Oct 24, 2014 | Washing Machines
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
How do I fix a f51 code on a whirlpool cabrio washing machine
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off. This was a cut n paste from a blog on that issue.
Apr 22, 2014 | Washing Machines
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi my dryer buttons seem all good but as soon as i start the spin it spins for a second then stops then it beeps repeatedly
Whats brand dryer is it? Older style or newer style. Is it the regular machanical timer style dryer or the new computer led light style dryer? If it the regular machanical timer style type, then you saying when you push the start button it starts but once you let go of the "push to start" button it stops. Is this right? In that case is could be a bad motor. The centrifigal switch in the motor is probably bad and isnt holding to the "run winding" in the motor internally.
Jul 30, 2009 | Dryers
Lights all Come on, Then spins up a few seconds then dies
Remove work bowl completely - then try the various buttons. If no spinning occurs with work bowl removed, the motor is dead. Find out from Cuisinart if you are still under warranty, and send in for repair.
Jun 08, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
LE Problem
An LE Error Code is indicative of a ?Locked Motor? or ?Overload in the Motor?. This is rarely caused by a problem with the machine and in most instances resolvable over the phone. Q1:Are there suds in the drum? -->Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor. Follow the steps below to resolve an LE error code caused by oversudsing. --> Step 1: Unplug the unit and let machine sit for 30 minutes to allow suds to dissolve. Step 2: Press the POWER button to turn on the washer. Step 3: Press the SPIN SPEED button to select ?No Spin?. Step 4: Press the START/PAUSE button to begin drain only. Step 5: After cycle is complete, remove the items from the machine. Press POWER to turn on, RINSE&SPIN button, then START/PAUSE. Repeat, if necessary. This will remove excess suds and light residue from drum. Do this until no suds are seen in drum. Q2: Is this a new installation? -->In new installations, the code can appear simply due to a miscommunication between the control board and the motor. In this instance, the unit will simply need to be reset, much like rebooting a computer. Unplug unit, press and hold start/pause button for 5 seconds, plug unit in and test with a Rinse/Spin cycle. Q3:Is a large load size in a gentle wash cycle? -->Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle. Q4:Is the washer overloaded? -->Single bulky items (comforters) or extremely large loads can add extra weight to the drum which stresses the motor. Remove some clothing and restart. If it doesn?t work, unplug unit and let it sit for 30 minutes to allow motor to cool. Then restart the cycle.
Jun 09, 2007 | LG WM1814CW Front Load Washer
Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery Logo
53 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
