Question about OpSwiss Optics
Rolling distances on rangefinder.
Does this rangefinder have rolling distances? Will it give you numbers as you scan or do you only get a number at the end of each attempt to get distance?
  • 17,115 Answers
Unless that device has a laser in it, rolling distance calculaters are hard to come by because they are not cheap.
Posted on May 06, 2013
Which is the best rangefinder for 500-600 yards?
The Ultimate Halo XRT62 7 Rangefinder
The Halo Rangefinder can reach as far as 600 yards if you are going for an insightful target. This rangefinder can reach 600 yards under proper conditions. Usually, deer is measured up to 200-250 yards. Too many distances make it generally harder to get correct measurements.
The Halo XRT62-7 gathers light well during a bright day you are completely set. It does not work better in low-light situations, however, as the display is not provided with artificial light. Practically, the rangefinder has been designed with the needs of shooters and golfers in mind, and in this Halo XRT62-7 Rangefinder review, you will know how this product has been helping your fellow golfers and hunters.
The scan mode and 6x magnification which allows for constant ranging. While you are involved on the golf course or in the woods hunting, Halo XRT62 has the rangefinder for you. The XRT62 equipped with a CR2 battery also with a useful protective case, class IIIA laser; 5mW or less.
This rangefinder also works nicely for golfing although you might have to try a few times to get a proper measurement. In such a case, the green object might be captured well by this rangefinder for measuring the distance.
Mar 15, 2018 | The Optics
Is Bushnell Scout DX Rangefinder is the good rangefinder?
The Ultimate Bushnell Scout DX Rangefinder
The Bushnell Scout 1000 is a pocket-sized laser rangefinder that offers a 5 - 1000-yard range with a +/- 1-yard precision in 3 diverse targeting modes: Scan, Bullseye, and Brush. The Bushnell Scout DX Rangefinder provides compact and lightweight design along with high-quality visuals to its 5 by 24-millimeter multi-coated optics.
It comes with a hard construction, water resistance, diopter adjustment, roll-down eyecup, a handy tripod mount, and features the ARC method with built-in inclinometer so you can get accurate distance on downhill or uphill shots.
Bushnell claims it will range a deep target at 1,000-yards, trees to 650-yards and a deer at 325-yards. It has a 6x21mm monocular for inspecting and aiming, weight 13.6 ounces and takes up 5.5 x 5 x 3-inches of space. There are a Cardura case, neck strap, and CR2 battery contained in the box along with a cloth to clear the instructions and clean the lens.
The ABS case has adequate non-slip surfaces to help users grip it securely, and there is a tripod hole if you want to have it in a stable position for some time. At this stage of our Bushnell Scout DX Rangefinder review, we will talk about the design of the rangefinder.
The Scout DX 1000 is a smooth and compact equipment that shares a similarity to the high-end G-Force 13000-series from the identical manufacturer. In addition, the best range finder has rubber armoring which provide a smooth and certain grip even when things get wet.
In fact, the Scout is fully water and fog proof which has a massive advantage out in the field. The Scout DX Rangefinder also has a flexible tripod mount that is placed into the bottom of the rangefinder.
Mar 12, 2018 | Bushnell Optics
How do I fix Leupold rangefinder not giving distance?
To what make and model of camera is this rangefinder attached ? Most modern cameras have autofocus lenses.
Jul 09, 2017 | Cameras
Bushnell Tour V2 2nd Distance Digit Missing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Jan 14, 2010 | Bushnell Tour V2 Pinseeker Laser...
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Dec 24, 2009 | Bosch DLR165K Laser Rangefinder Kit
I have no manual, how do I get the distance number to appear?
You can download a manual at http://distagage.com/downloads.html
but simply, to get the distance to appear, turn on the unit with the large red ON/DIST button, aim the red laser dot at your desired target, and press the ON/DIST button again. The distance will appear on the display screen.
Greg DeTray, www.distagage.com
Oct 14, 2009 | Leica DISTO A5 Rangefinder
Pinseeker 1500 has trouble picking up flags over 100 yards away
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
mr tech geek Rate me if you can...or find out this is the truth!!!!
Bushnell Repair Technician
Service address:
Bushnell Repair Centre
8500 Marshall Drive
Lenexa, KS 66214
send $10 for return shipping
send your problem statement and phone number.
Their number is 800.423.3537
Jul 16, 2009 | Bushnell PinSeeker 1500 20-5103...
My range finder powers up but doesn't give distances
If your unit powers up and all the lcd segments are on.....The main circuit board has lost its programming. Check the model number. (on the back on a small black strip) call bushnell and find out if it can be reprogrammed. If you have the model in the picture it can be reprogrammed but, there is no guarantee how long that will last. I would look at some newer technology.
Good Luck to you!!!!
mr tech geek
Jun 30, 2009 | Bushnell Yardage Pro Sport Rangefinder
Range finder does not register distance 99.9% of the time
I had the same problem, rangefinder would work only sometimes and only at short distances. Called customer support and was ready to send it in. Tech guy told me to turn off "First Target" ( or "last target") and turn on"LOS" (line of sight). Range finder now works perfectly at all distances. Apparently the first target feature doesnt work properly.
Dec 26, 2006 | Leupold RX-II Rangefinder
Long range mode
To turn off: push the power button twice while 150 is blinking and once to turn it on.
Aug 13, 2006 | Leupold RX-II Rangefinder
Optics Logo
79 people viewed this question
Top OpSwiss Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an OpSwiss Optic Expert? Answer questions, earn points and help others
