Question about Sewing Machines
Babylock companion 1550
Top tension is has to be set to seven but still off. do i need to take cover off and check. bottom ok.
  • 1116 Answers
SOURCE: Thread tension won't adjust properly. Top thread is ok, bottom ,
I could be as simple as threading the machine with the presser foot up.
When the foot is up, the tension opens and accepts the thread. Foot down and thread cannot enter as it should.
Out of control upper thread can look like a bobbin tension problem.
Posted on May 19, 2010
Testimonial: "Thanks, bobbin was the problem. works now."
sewinsnap
  • 135 Answers
SOURCE: tension setting
NEVER adjust the bobin tension, you will need to take it to the shop now to get everthing set right again
Posted on Aug 12, 2010
  • 161 Answers
SOURCE: I need to know how to thread a babylock companion
http://www.sewingmanuals.com/
also you might be able to find a tutorial in you tube
Posted on Sep 12, 2010
SOURCE: tension settings for the babylock sewing machine
My babylock 1556 bobbin thread is too loose when sewing, how do I get that tightened up?
Posted on Mar 15, 2011
Tally Girl
  • 1129 Answers
SOURCE: How do I set up
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Posted on Oct 16, 2011
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
How to fill a spool on a 1550.
a 1550 what ? we can not read minds here
Jan 07, 2017 | Sewing Machines
Where does the tension spri ng go on my babylock 1550 bobbin winder
It may be worthwhile to purchase a new bobbin case for your machine. Trying to re-attach the spring will most likely cause the spring tension to change making it difficult to get the tension correct. Bobbin cases do wear out and really are not all that expensive to purchase. A lot of sewists keep more than one bobbin case on hand so they can adjust a specific case to accommodate the tension for specific thread weights.
Dec 29, 2016 | Sewing Machines
I need owners instruction manual for baby lock companion 1550 sewing machine.pls help where can i download free manual.
You can check with a Baby Lock dealer an online sewing machine parts vendor, or even eBay. However, it may be difficult to find a manual for your machine due to its age and perhaps even less chance of success for finding a free manual.
Baby Lock Manuals
http://www.sewingpartsonline.com/babylock-sewing-machine-instruction-manuals.aspx
Babylock Sewing Machine Manuals Instruction and Repair Manuals
Babylock Sewing Machine Manual PDF and CD
Nov 27, 2016 | Baby Lock Sewing Machines
How do I thread a baby locks companion 722
You may try locating a manual:
http://babylock.com/search/index.asp
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Babylock/Babylock_722_instruction_manual.htm
May 17, 2016 | Sewing Machines
Can someone tell me where to get a free downloadable Babylock BL1550 sewing manual.
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Babylock/Babylock_BL-1550_instruction_manual.htm
Jul 03, 2015 | Sewing Machines
Baby lock companion 1550 manual
I need a owners manual for a baby lock companion 1550
Mar 06, 2013 | Sewing Machines
Bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Apr 26, 2009 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
