Question about Lenovo ThinkPad Computers & Internet
Error code 0000 read verification failed - ThinkPad Lenovo Computers & Internet
2 Suggested Answers
SOURCE: i am getting the blue
Enter Bios from there search for SATA mode . then try to change it from ahci to ide . and then save and exit . if this also wont work try to foramta the hard disk
Posted on Jan 27, 2011
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
Tip
Detail
Code
E000
0000
E001
0000
0001
0002
E002
0000
E003
0000
0001
E007
0000
E010
0000
E014
000
E019
0000
E032
0001
E051
0000
E064
0000
The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
on Dec 08, 2009 | Office Equipment & Supplies
Adrees Cheema
G6600 unlock done with infinty..........................
COM6 [VCP0] selected
module v3.62
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G6600
Checking data, wait...
Phone should be Switched OFF !
Press and HOLD Power button now !
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E5.2FY01V01.09
Version: BYD35_09A_PMWY_HW
82 byte(s) read
imei: 35751003xxxxxx
connection Ok
189 byte(s) read
reading data...
building new data...
writing data...
177 byte(s) read
reading data...
reading data #2...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 1 min 58 sec
Remove/Install battery now !
Feb 07, 2014 | Huawei Unlocked G6600 Qwerty Smart Cell...
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
I am getting the blue screen of death . After running the hard disk drive diagnosis test on my lenovo think pad l410 im getting the following result.. error code 0000 read verification failed how do...
Jan 27, 2011 | Computers & Internet
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
It sounds like you may need to Update the Drivers. If not you may have a Bad Sound Card.
Jan 22, 2009 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
