Question about Breville You Brew - Single and Carafe Serve Coffee Maker w/ Grinder
You brew code 01
After grinding the beans,the LED flashes 01 and stops. I clean the stainless steel disc after every usage...anything else I should do? Thx
3 Suggested Answers
SOURCE: beans wont grind through.
Return this machine to your retailer for another. Breville has a replacement warranty. Thank goodness because we are onto our 4th machine in 7 months. Many problems. Firstly it leaked water from the front of the machine, second machine grinder wasn't adjustable so it grinded too fine for pump, same with 3rd and 4th machine. We are opting for a refund tomorrow! Good luck.
Posted on Aug 01, 2010
6ylucy
  • 742 Answers
SOURCE: cannot remove stainless steel brew head
Hi Roberto, thanks for your message.
I am quite sure that the brew head removal will be described in the service manual. I found that here:
http://tradebit.com/visit.php/84445/product/-/150234770
Posted on Dec 10, 2011
Delonghi problems
More than likely the grinder is either not grinding at all or there is a blockage preventing the grounds reaching the brew chamber.
Jul 18, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Stops after grinding beans
cva 2660 doesnt grind beans it uses nespresso capsules.
Jun 03, 2012 | Miele CVA2660 Stainless Steel Coffee Maker
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Where does the water go
This is a COFFEE GRINDER. Designed to grind coffee beans to into a powder . This powder is then put in a coffee machine or a coffee peculator to brew coffee. DO NOT put water into the coffee grinder !
Dec 19, 2010 | Breville Conical Burr Coffee Grinder -...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Breville You Brew - Single and Carafe Serve Coffee Maker w/ Grinder Logo
93 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
