Question about KitchenAid Dishwashers
Kudl2rir not working only when i push cancel pump will run
Troubleshoot my kenmore dishwasher won't drain
Check that the drain hose isn't kinked or blocked. Check that the pump inlet in the bottom of the dishwasher isn't full of gunk.
Oct 13, 2014 | Kenmore Dishwashers
Dishwasher will not run. Air Dry/Lock on light blinks and unable to turn off even if held for 4 seconds. If you press Start, "Quick Rinse" light comes on and blinks along with the Air Dry Light....
Sound like you might have a fallty drain pump. When you turn the power off and started again, did you hear noise of pump draining the leftover water. If not , then you have a pump problem. Need a service man. Good luck !
Feb 11, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
The clean light keeps blinking and the dishwasher will not start. I pushed the cancel button and it runs for about 30 seconds and just shuts off. Nothing happens when you push the start button.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 01, 2011 | KitchenAid Dishwashers
Dishwasher will not drain
If you can close the door, turn the control to drain and, can hear the motor running; you have a clog under the pump screen in the back of the Dish Washer preventing the pump impeller from turning
if you hear nothing: reset the house circuit breaker.
to fix: while the DW is on turn off the DW house circuit breaker then remove the pump screen and, remove the broken glass etc. from the pump then: repower and, test.
May 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
F02
this is a long drain code on the whirlpool washers. when the drain time exceeds 8 minutes, the water valves turn offf and the f2 code appearsr.
push the pause/cancel key 2 times to clear it.
Around 4 minutes the sud code will show, then 4 minutes after that the f2 will show.
1)Inspect the drain hose for clogs or kinks.
2)Check the electrical connections to the pump and listen to see if u hear the pump running.
3)Check the drain pump filter for debri.
4)And finally if what i said previosly does not work then u must replace the pump.
Jan 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool quiet cycle III that won't start
Check the whirlpool web site. There is a link to see if yours is affected, click that and answer a couple of questions then if will ask for the serial number and then the model number, which are located on the inside wall of the washer. When you submit these numbers it will tell you if yours is recalled which is probably the cause of your problems as well. Since mine was doing something similar and it is one of the washers on recall for a bad motor.
Jun 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
