Question about Microsoft Xbox 360 Console
Drive problems? my disc wont read and the door will not close when I turn off the system I have to push the door back in once my system is off. What could be the problem.
  • 20 Answers
Your mechanizem system is broke due to frequent close and open may be soemtimes you use your hand now you have to repair this system .
Posted on Aug 10, 2007
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
How to open driver door
Do you mean the disc drive tray won't open? Or do you mean you have a front panel cover on your computer that won't open? If the disc drive tray won't open it could just be stuck, if you look closely at your disc drives front panel you'll see a small hole, take a paper clip our some thing about 3 inches long that will fit in the hole insert it into the hole you'll feel it bottom out if you push on the paper clip firmly your disc drive door will open, ( I would do this with the computer turned off) If there's a disc in there take it out if not just push the try back closed don't force it completely closed it will do that itself, now turn on your computer let it completely finish booting and see if it the drive works. If it does not it's probably time for a new disc drive. I hope this helps
Jun 22, 2012 | eMachines EL1360G-UW11P Desktop PC
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
Wont eject disc an wont read disc? cant play game
well it could be a few things for one if someone tried to push a disc in while there was already one in it then this will bend a metal guild in the drive and keep it from taking a disc of even reading it once it goes in, or you have a dead drive, if this is the case nintendo has an exchange program and you can send it in and get a good init back...
Mar 24, 2010 | Nintendo Wii Console
DVD player not reading or playing DVDs or CDs
it can get damaged that way. but try rebooting yoru computer first. sometimes that can clear the problem if it just didnt load up correctly in the system. if that dont work, try rolling back the driver, if still samething then uninstall drivers and reinstall.
Apr 22, 2009 | Acer Computers & Internet
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
PS2 Slim Won't Read Discs
theres a wrong in the mechanism in your PS try to push the cover while reading the disc, push it on the surface which the sensor was locate, "push Gently" not very hard!!
Aug 26, 2008 | Sony PlayStation 2 Slimline Console
Dvd, fix it or pitch it?
no these are legitamate questions, the one that wont eject is probably out of timing someone could have pushed the door closed instead of pushing the button a lot of people dont realize this can harm a player what you would have to do to fix this is open it with the power off then plug it in and let the power close it that will normally fix that problem. the one that reads no disk listen and feel for it to spin the disk when turned on if the disk dont spin it wont work let me know what it does or doesnt do. the x box could be a lot of things but listen for disk to spin in it also and get back with me some might be fixable some might not.due to cost
Dec 09, 2007 | H45 Quick DVD External DVD Drive
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
