Question about Boating
Everude 35hp starts but will not keep running
  • 56 Answers
You can find an answer on the Johnson & Evinrude forums.
Posted on May 07, 2013
1997 3cyl 25HP Evinrude outboard Would changing the carbs to 35HP carbs make this a 35HP motor?
Depends if the bore and stroke are the same, if they are not, adding larger jetted carbs can result in always running rich. The mixture would be incorrect for the amount of air the cylinders take in.
Feb 02, 2017 | Cars & Trucks
I have a 35hp, motor runs well , but water isn't circulating to cool engine . can you help with a solution. fred
check your intake screens. Yo may have to replace the impellor on the water pump.
Jan 03, 2015 | Boating
1959 35HP BIG TWIN WILL RUN SHORT TIME AT HAFE TROTEL THEN DIE
I need more info. Two hose fuel line? If single hose with primer bulb, can you keep it running by pumping primer bulb? Picture would help. Will it idle for longer? Will it go over half throttle?
Jun 25, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Stalls in inital take off
Hi. Replace the fuel line inside the motor, the fuel line to the tank and then get a bottle of a fuel additive called seafoam to clean out the engine. Also check the plugs and replace them if necessary.. This routine usually works. J.
Aug 01, 2010 | Boating
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
Force 35hp 1988 hard to restart
Its possible the coil is overheating but you could be losing fuel pressure. If you have a air leak in the fuel line it will drain back to the tank.
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
