Question about Dometic Rooftop RV Air Conditioner
Frigidaire window air conditioner, new, fan won't run
Bought from Lowes, unpacked, installed, lights come on but all I hear is a humming and occasional compressor noise (I believe). Fan won't run, tried every imaginable combination of settings, just a humming sound. (is there any packing material INSIDE the unit I need to remove?)
    Genius:
  • Dometic Master
  • 1,363 Answers
Slide out and spin blade by hand. should be able to tell if anything restricting rotation
Posted on Aug 23, 2015
motor1258
  • 6674 Answers
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Posted on Aug 14, 2008
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 127 Answers
SOURCE: Brand new Duo Therm won't stay running
You really need an Ammeter to check this problem. Just because it is a brand new unit does not mean that there isn't a problem with it. Is it run off of a wall thermostat or manual controls? The compressor has a thermal overload switch on the top (under the plastic cover) that will take the compressor out of the circuit if it gets too hot. However, if the entire unit is shutting off, there is another problem. Selector Switch? Thermostat? Let me know what kind of controls you have and we can go from there.
Posted on Jul 02, 2009
VtToolMan
  • 704 Answers
SOURCE: RV Air Conditioner Keeps Tripping Circuit Breaker & Compressor
It sounds like the unit was miswired at the factory, since when the A/C is "off" at the thermostat, there should be no calls for cooling or for the fan to run.
You also stated the most puzzling issue, with the breaker turned "off" the same thing happens. This shouldn't happen at all, when the power breaker is turned off, there should be no power being supplied to the unit and it shouldn't be able to do anything. Very strange indeed, but likely a major error done when the RV was manufactured, or some wiring in the loom has somehow become shorted and is supplying power from another breaker/source.
I think a call to the manufacturer is in order since there is no easy solution aside from possibly rewiring the A/C circuit.
Not sure when your RV was made, but definately time to call the manufacturer and break out the wiring schematic in an attempt to isolate and resolve the problem.
Hope you find this helpful and best regards!
Posted on Aug 06, 2009
  • 415 Answers
SOURCE: AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Posted on Mar 31, 2010
Testimonial: "You gave us a couple extra ideas than what we already thought of checking. Thank you. We will trade out parts from working one, see what it is. Thanks"
Took it out of Box, Pluged it in to First Make Sure it Worked and It VIBRATES So Bad Im Scared to Install it.....What should I do?
If you think something is wrong with the air conditioner, you take it back to the store. No a new air conditioner should not vibrate violently. They are pretty quite, so take it back to the store, and exchange it for another one.
Apr 07, 2014 | Frigidaire 5000-BTU Window Room Air...
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Window a/c compressor runs. fan hums but does not run
Replace the fan. The bearing is worn and it may need a new capacitor.
Jul 14, 2012 | Whirlpool ACQ158XP Wall/Window Air...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
Bought a new remote because i lost mine and it won't work
i bought a logitech / harmony univercial remote and it is unreal you sync it on your computor it is realy easy and very effective, has a huge range of devices , costs about 30 dollas
Jun 06, 2012 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Dometic Rooftop RV Air Conditioner Logo
163 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
