Msi n1996 motherboard
Hi,there.i want to know msi moterboard 1996 v4.2.hard disck suppurated name like:ata sata or others
  • 32,281 Answers
This motherboard supports IDE/ATA hard disks
You can download the specs from this WEB site
http://www.specsbox.com/142/msi-n1996-motherboard-specs.html
Posted on May 06, 2013
smeago1
  • 136 Answers
SOURCE: Problem with SATA WD Caviar SE WD2500AAJS hard drive model
hey there
there are tiny little jumpers on the hard drive itself there's also a diagram that tells you what jumper to set..basically there's only about 3 options try the other two options then plug it on the mobo and then try to see if the mobo detect it.
one of the option WILL always work.
good luck
smeags
Posted on Jan 02, 2008
  • 32 Answers
SOURCE: Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Posted on Jan 20, 2009
  • 191 Answers
SOURCE: Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Posted on Oct 09, 2009
Testimonial: "How DO I sent u a message??? PLease help"
phil_frye
  • 295 Answers
SOURCE: My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Posted on Nov 19, 2009
  • 76 Answers
SOURCE: 500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Posted on Apr 08, 2010
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
I want to know if I can use sata hard disc with motherboard MSI N1996 and where can find the manual of the motherboard
this motherboard looks it has an eide controller you might have to check your PSU power supply units power ends that they have the sata end also you might have to check the motherboard for the IDE or SATA connection or use an adapter if it only has an IDE connector
http://www.firingsquad.com/hw/130/MSI_KM2M_Combo-L_MS-6738-010/?viewdesc=1
hope this helps
Apr 23, 2011 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Hi, I have a msi n1996 865gvm3-v motherboard and it doesn't want to pick up my sata drive, what to do?
If you are trying to install Windows XP and it does not detect the SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 14, 2011 | MSI 865GVM3-V Motherboard
I just bought serial ata 160 gb hard drive can I use this with this mother board?
Unfortunately not without purchasing a serial ata controller card as this motherboard only supports the IDE drives.
Mar 03, 2011 | MSI KM4M-L Motherboard
MSI MS-7142 motherboard problem is not support 500gb sata hard drive
Your motherboard can connect up to 2 serial ATA devices and for this reason, it can support a 500GB sata hard drive.
Oct 11, 2010 | MSI K8MM-V Motherboard
Msi n1996 driver
Download here
just click the link then in rigth side use mannualy download
select the exact model of your unit
http://www.msi.com/index.php?func=downloadindex
Sep 06, 2009 | Intel Motherboard
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
