Question about iRobot Roomba 560 Robotic Vacuum
Not sucking properly - iRobot Roomba 560 Robotic Vacuum
  • iRobot Master
  • 18,389 Answers
Make sure brushes and filter are clean,this link is for the manual
http://www.irobot.com/images/homesupport/Manuals/00152.0210.v1.ALLRoomba.Manual.EN.pdf
Posted on May 05, 2013
Testimonial: "Hi i have replaced the brushes and filters with new ones and even checked that the vacuum fan was spinning after taking off the rear gauze. I have cleaned all dust out of roomba. it just wont pick up the bigger objects like it used to (ie. sultana, small bits of paper, dead grass bits etc.)"
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
The cleaner is not sucking up the water from the carpet
There should be a filter. If it's clogged or old, water will not flow through it properly. Meaning... Your machine will not suck the water up, once you've made a big mess on your carpet.
Good luck and Merry Christmas, Bill
Dec 19, 2014 | Vacuums
Vacuum not sucking
Check for a block in the hose and the bag is in properly allowing the lid to latch.
Jan 09, 2014 | Miele Vacuums
When the brush is on it won't **** properly
Look for blockage carefully as the unit does not know which you have attached.
Dec 05, 2012 | Miele S7210 Bagged Upright Vacuum
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Brissell proheat is not sucking up the water solution. Usually, I see the bubbles and dirt getting sucked up.
We would like to provide troubleshooting suggestions to get your machine suctioning properly. Please call us when you are with your machine at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Jul 05, 2010 | Bissell Vacuums
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
positioned.
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Apr 30, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
61 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
