Question about Zareba Sp3 Solar Power Fencer
No power zareba fencer new battery red indicator light is working but no power?
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
If it is new, send it back, but make sure you carefully read the instructions first. If is says the indicator light is red on charging and green when fully charged and it doesn't do that then the batteries or the charger are defective.
In future make and model are useful. And you posted to electric drills, but I recategorised it.
Jul 02, 2017 | Audio Players & Recorders
What can you advice me to do? i have a UPS SURTD5000XLI, indicating a red Led light, but when i remove it from the AC power source, the Red Led also remove & when i flog it again to the AC Source it...
Is red light on for overload or for battery?
If on overload, try reducing the load on the UPS. If red light on overload persists buy a new UPS (overload fault hard to repair).
Red light on battery - replace the batteries.
Red light on boost or buck, may mean that the nominal voltage of ups and the limits need to be changed/corrected.
Jun 23, 2014 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
I have a Harbor Breeze White 3-Speed Combination Fan and Light Control (Model #: WC-100L) that has stopped working. The red power light does not even light when I push the buttons. Any idea on...
First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
Oct 17, 2013 | Dryers
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
Controller has no voltage output when connected to fence
You have a dead short to ground somewhere along the fence circuit.Disconnect the leads again,and use a resistance checker to check resistance to ground.(Push a metal rod into the ground to connect one of your leads to,and connect the other lead to the fence.)One or the other fence circuit ends will have a lower resistance to ground.That fence end is closer to the short to ground.Follow that part of the circuit until the resistance to ground is as close to zero as you can find.(taking the ground rod with you as you go)Somewhere in that area you will find your short.
May 15, 2009 | Zareba Electric Fence 600 - 7,000 Volt...
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Zareba Sp3 Solar Power Fencer Logo
131 people viewed this question
Top Zareba Renewable Energy Experts
Marco De La Fuente...
Brian Lee
Kelly C
Kelly C
Level 1 Expert
Are you a Zareba Renewable Energy Expert? Answer questions, earn points and help others
