Question about Kyocera Office Equipment & Supplies
1500 printer message 210 A-0 what it means?
What does fault 072-210 mean? how to fix it?
An error occurred when using Tray 2. Turn the machine off and on. Most likely worn feed rollers, causing a "Ghost Jam" try replacing the feed rollers in the tray, and try again.
Jun 05, 2014 | Xerox Workcentre 5225 / Copier, With...
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
Pixma mp 240 does not recognize cl 211 and 210
Hello , i have the same problem but vice versa. i bought my printer with the 210 and 211 cartridge and i bought now the 510 and 511 and the printer wont recognize them . all i know is that my printer is specially made for canada thats why it works only with 210 and 211 , so urs must be european because 510 and 511 are the cartridges for the european version of this printer . i've tried so hard to trick the printer so accept this cartridges but its not working . did u find a solution in the mean time ? i could really use some advice
Jul 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
Canon MP 210 message "Your Ink Absorber if Full"
kindly follow this steps, Reset Printer Canon MP210, Start with printer off
  1. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  2. While holding the Power button, release the Resume Button.
  3. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  4. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  5. Turn off the printer and turn on again .
this process will remove the error.
Nov 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Brother 210 C Unable to Clean message appears in
Probably it's waste ink tank is full.
Try this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is I assume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set". Do the same for numbers 7, 8 and 3. After you have entered this combination, the purge numeric value will be reseted to 00000.
Sep 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Copystar CS-1500 "OP" flashing in display
Hello, 'OP' means that the front or upper front cover is open --- close the cover securely. If the message is 'OP1" then the left cover of the document processor is open, close that securely.
Jan 05, 2009 | Copystar CS-1500 Copier
Machine error a1 - Manual Clean
machine error a1 means: scanner open which is an info. You dont have to disassemble the ph!
Apr 06, 2008 | Brother DCP-110C All-In-One InkJet Printer
CF 210 Delonghi
i just found out that e3 means voltage problems. i plugged my into a place i knew would have enough voltage and it started right up with ac
Sep 10, 2007 | DeLonghi CF210 Portable Air Conditioner
27 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
