Question about RCA F32649 32" TV
Tv problem when I turn on my TV I hear a click,(turning on) but right after I hear a click (turning it off) this is repeated with out me touching anything and my TV doesn't stay on.
  • 4 more comments
  • minnie79 Aug 10, 2007
    yes it switchs off by it self then repeats on and off clicking by it self, but the tv never stays on
  • jcinar Dec 01, 2007
    I have the same problem but it only does this with the remote control. the buttons on the front panel don't work at all. I took out the circuit board that has the micro switches on it and checked them out with an ohmmeter and all of them work. Sometimes I can get the TV to turn on but then the channels just keep cycling through one after the other. It will not stay on any one channel.
    I put the TV in my garage (unplugged) for about a week then tried it again and it worked perfectly for about two weeks then the same problem again. I don't know what to do to fix this thing and I can not find any repair places in my metro area.
  • betzy1 Dec 31, 2007
    the Phillips tv clicks on the clicks straight off without coming on. The red light flickers
  • tuckp79 Mar 03, 2008
    its turning off and on im trying to find out what part i need to fix it
  • sownia May 07, 2008
    The Sony Wega 32" widescreen TV, when i try to switch it on( either thru' remote or direct switch on the TV), it switches on and off on its own and the red light flickers as if someone is really switching it on and off. After several times on and off on its own, it then stays on. But once it is switched off, the same problem occurs to switch it on again
  • RDJones3 May 27, 2008
    My TV flashes from channel to channel non-stop. Sometimes it turns off and on by itself. I had to unplug the TV because it's "possessed" by a Gemlin! I've left it off for extended time, and sometimes it works normal for a short while upon turning it on. Then other times it begins flashing from channel to channel non-stop immediately upon turning the set on. Any clues as to what causes this, and is it an "expensive" repair job? I took the batteries out of the remote control, and it still does it with the batteries out of the control. So I assume it's a problem with the TV set.
Went the tv swith on it swith off by itseft
Posted on Aug 10, 2007
3 Suggested Answers
  • 1694 Answers
SOURCE: agrabka@hotmail.com
Probable bad flyback transformer, common failure GE, RCA &
Proscan ( Thomsom Mfr.).......provide service number off back of set and I will get you Part #..............................
Posted on Dec 03, 2007
  • 4 Answers
SOURCE: my TV doesn't stay on.
hello i have a feeling that your problems are of the same root cuase its a leaky flyback transformer or LOPT
Posted on Dec 21, 2008
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
FD Triniton Wega XBR KV-30XBR910 TV WON'T TURN ON, LIGHT FLASHES 6 TIMES RIGHT NOW, SOMETIMES IF I KEEP TRYING USUALLY SEVERAL WEEKS AFTER TURNING OFF IT WILL TURN ON, BUT WILL EVENTUALLY TURN ITSELF OFF...
If you are handy with TV repair then replace IC6501 and IC8002 on D board of TV or ask local TV repair shop to replace it. Both ICs have same number MCZ3001D
Thanks.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on, relays click repeatedly
Flyback is the most problem assiociated with the clicking so a replacement will solve the issue..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | RCA 27V530T 27" TV
My TV doesn't stay on.
Jun 18, 2008 | RCA F32649 32" TV
TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
May 12, 2008 | Televison & Video
Agrabka@hotmail.com
Nov 18, 2007 | RCA F32649 32" TV
Problem with televison...please help
Replace IHVT aka flyback #257805 or Asti 2078.
Mar 29, 2007 | RCA F32650 32" TV
RCA F32649 32" TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
