Question about Koolatron CocaCola Fridge Red Compact Refrigerator
Pf error code - Koolatron CocaCola Fridge Red Compact Refrigerator
What causes pf error code?
not much info on make or model- always better to put as much detail as you can, but taking your q at face value, the question has already been answered by a kind fixit contributor PF Error Code for Appliances
May 13, 2014 | Heating & Cooling
Tip
<p><br /> <p>There is one<b> <i>Error Code that is almost universal to most any appliance</i></b>. The<b> PF or Power Failure code</b> is usually the same no matter what <b>type of appliance</b> or <b>brand</b> you are working with. Even with the fact that this <b>error code is so common</b>, I still see many questions on <b><i>www.Fixya.com</i></b> that are asking <b>what the PF Error Code means</b>.<br /> <p><br /> <p>So now the next question is this.<br /> <p><br /> <p>What causes the <b>appliance to give you the PF error code</b> in the first place?<br /> <p><br /> <p>The most common cause of your <b>appliance giving you the PF error code</b> is a problem with the <b>power coming in from your utility company</b>. Of course if there is an <b>interruption of power</b>, and then the power comes back on you will get the<b> PF code</b>.<br /> <p><br /> <p>Some <b>appliances will give you the PF code also if the power voltage goes low</b>, or goes into a <b>brownout</b> condition. Depending on the sensitivity of the <b>appliance control</b> you may also get the PF code for other reasons such as <b>frequency problems</b> or <b>voltage fluctuations</b> or <b>power spikes</b>.<br /> <p><br /> <p>The other <b>problems that can cause the PF error code</b> can be internal to the appliance.<br /> <p><br /> <p><b>Loose wires going to the circuit board</b> or the control can also be a <b>cause of the error code</b>. If a <b>wire terminal end</b> happens to get <b>corroded</b> or loose, the <b>vibration from the machine</b> can cause slight power problems and this can <b>cause the PF code to be displayed</b>. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by <b>banging on the side of the appliance</b> or <b>slightly moving the wiring harness</b>, to see if you can get the error code to display.<br /> <p><br /> <p>The bottom line about this <b>power failure error code,</b> is that it is <b>power related</b>. Finding the exact cause can be difficult. If you are continually having to <b>reset the appliance</b> then check to see if all of your appliances are giving the same code. This will indicate <b>utility power problems</b>. If only <b>one appliance is giving the PF code</b> then it is probably internal to the appliance.<br /> <p><br /> <p>
on Mar 06, 2011 | Refrigerators
We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
heatman101
0-=0
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
My whirlpool dryer is getting an error code pf. What does that mean?
heatman101
Jul 19, 2010 | Whirlpool WED8300S Dryer
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
heatman101
,./;''l
Jun 18, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
PF Code as soon as try to start dryer, you get the code when select the time
heatman101
p[[p
Mar 14, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Koolatron CocaCola Fridge Red Compact Refrigerator Logo
46 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Jerry Kramer
Jerry Kramer
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
