Question about iRiver Spinn MP3 Player
Irriver spinn 8gb repair
My device is not switching on since days... how can i do an authorised chek up and fix it?? any trusted sevice centres?? please respond..
Microwave gone dead 2nd time
thats easy - ITS WARRANTY - take it back -
Nov 28, 2013 | Microwave Ovens
Micromax A56 is hanging since last 15 days
Dear friend,
Since you are using complicated android device, I can't tel you the exact fix for your problem without handling your device or live conversation.
Your ppssible causes are:-
> viruses in your device.
> Low amount of free RAM,
> corrept mother bord.
> miss handeling with settings.
To fix your problem do the followings:-
> give a good virus check to both your device and memory card,
>boost your RAM by closing those application which are not in use, always keep RAM to 100mb free memory.
>if you still facing the problem then give a factory reset to your device.
> if still the problem exist, give your device to an authorised service centre they will change *********** board.
Regards,
Priyank Abhineet.
Oct 13, 2012 | Cell Phones
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
My problem is my laptop cant open or cant read a usb device why? its toshiba and the procesor is win vista
check that all drivers for the usb port are installed ? for that you can go to device management and click on universal serial bus controller a yellow coloured question mark indicates that there is not driver installed for the device.update it with the required driver either from the driver disk that came with the laptop or from the internet driver.com ,or seach internet by google entering the brand and model of the laptop..
if it does not works then there is a problem with your usb device controller chip on the motherboard you need to get it serviced by some authorised service centres . i will highly recommend you to go to a company authorised service centre and not to any local computer hardware technician .only a company authorised person can solve/repair the motherboard ...your motherboard is likely to be damaged if serviced by some un-authorised/untrained personal
Dec 06, 2010 | Computers & Internet
Sir i have a thomson tv model of V21TF02. 15 days back a little bit of the board has burnt by current shock cerkit. here in karnataka any cervice centre are avilable for solve this problem. and procedure...
Hello
There is an authorised sevice center for Thomsun in karnataka. You just sech for it on google by entering 'Thomsun auththorised service center in karnataka' in the box. You will get a map showing the location of that service center, which I gets here in Trivandrum, Kerala.
There is no need to insist on to an authorised service center, to get your TV repaired. Just consult with local electronic mechanic, in this case, They can do the needy very easly.
Ok.
Nov 23, 2010 | Thomson 21DC320 21" TV
Repair manual for HP Pavilion dv6 1245 dx
Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Mar 16, 2010 | HP Pavilion dv6000z Notebook
My 8gb touch will not switch on, can you help me
1. Is the battery charged? 2. Is your USB port providing enough power? 3. Is the cable ok? If the battery is really flat then the power from the USB port may not be enough. Try plugging it into a wall charger. If all this fails then it's broken. If it's under warranty (12 months), take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days No warranty? Google "iPod repairs" in your country and you should be able to find someone who can fix it. The usually have a self diagnosis on line so will get an idea of the cost before you begin
Dec 01, 2009 | Apple iPod touch
My lock symbol wont come off my ipod can you please help?
1. Try sliding the little switch on the top on and off several times. If that doesn't work the slide switch is broken. If it's under warranty (12 months), take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days
Nov 30, 2009 | Apple iPod nano
Motorola W375 mobile phone
Dear Sir/Madam,
This problem fix only authorised service centre. Because the screen is filled with water. So u can replace the screen. Only authorised service centre have the original parts. So plz contact service centre for help.
Thanks
Good luck
"Don't Forget to rate the solution"
Jun 24, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
iRiver Spinn MP3 Player Logo
16 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
