Question about Bernina Artista 180
Birds nest when sewing the thread always birds nest?????
  • 1 more comment
  • soccermom15 Aug 14, 2007
    Thanks for the help. but it didn't work
  • soccermom15 Aug 15, 2007
    Just wanted to let you know I fixed the problem. I found a burr on the rotary hook.
    Thankyou so much for the help.
  • Anonymous Mar 16, 2014
    bobbin birds nest
  • 691 Answers
Check the tension on both the upper and lower threads is similar. It sounds like the thread on the lower spool is under tensioned. On most machines the tension is increased by a small screw on the spool.
Posted on Aug 14, 2007
  • Inky Fingers
    Inky Fingers Aug 14, 2007
    Generic Tension Info for lower thread
  • Inky Fingers
    The only other suggestions I can make are to ensure that you have the correct needle type for the application and make sure it is a good one.
    Make sure that you have cleaned out any lint etc from the mechanics.
    Knots and nests are usually caused by incorrect tension.
    Get some scrap and try making small adjustments and trying the results before adjusting again.
1030 not sewing, will start and then quiets, has birds nest under frantic
What brand is a 1030?
For birds nest:
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning,.
Feb 17, 2018 | Sewing Machines
Thread keeps tangling on underside
Called thread nesting or bird nesting.
Install a brand new needle that is compatible with the thread and fabric you are using.
Remove the top thread totally from the machine.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning.
Confirm the thread path is correct.
Retest your machine.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jul 23, 2017 | Sewing Machines
Nesting thread on bottom of fabric
This is called bird nesting or thread nesting. It occurs most often because the thread is not seated completely in the tension disk.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
It also may help to use a brand new needle.
Jul 19, 2017 | Sewing Machines
Why does the needle make knots at the bottom?
Those are called bird nests or thread nests (or what I prefer to call thread barfs).
The most frequent cause is that the presser foot should ALWAYS BE RAISED when threading the top thread.
TIP Avoid Thread Bird Nesting with these Four Tips Stitching Sewcial
Jun 13, 2017 | Sewing Machines
Bobbin thread is gathering up under Neath
Sounds like birds nest or thread nests. HINT: When threading the top thread, ALWAYS have the presser foot in the RAISED position.
Sewing Machine Thread Bunching Up Here Why
May 09, 2017 | Sewing Machines
Elma supermatic balls up under machine after a few stiches
Thread nests (also called bird nests).
Remove the top thread.
Apr 23, 2017 | Sewing Machines
Have lots of thread on the under side of fabric
Thread nesting or bird nesting resulting usually from: mis-threading, upper thread not seated completely in the tension disk, upper thread tension too loose. HINT: ALWAYS raise the presser foot when threading the upper thread.
Jan 05, 2017 | Sewing Machines
Sewing Machines Logo
226 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
