Question about Welding Tools
Fuse location 185e Rossi mig? - Welding Tools
2 Suggested Answers
  • 2210 Answers
SOURCE: changed polarity on the rossi 220 amp mig welder but still won't weld
What do you mean "it won't weld" ? Does the wire come out when you press the trigger? If so and there's no spark when you ground it then check the heavy relay that operates the heavy juice. Tell us what you have done and tried so far.
Posted on Dec 05, 2014
What is the switch 1 and 2 for?
Probably heat (voltage) settings, which would probably also speed up the wire. If you have a voltmeter, you can check the open circuit voltages in the different settings.
Jun 22, 2015 | Welding Tools
Changed polarity on the rossi 220 amp mig welder but still won't weld
Dec 05, 2014 | Welding Tools
Rossi arms
Yes you can but you didn't include any model info, just that it's a Rossi brand.
So, start here:
http://www.gunpartscorp.com/Manufacturers/Rossi-33467.htm
Shotguns are at the bottom of the list.
Aug 23, 2014 | Optics
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
My mig welder will not weld at all no spark ...
Remove from power, check internal fuse, and check the trigger connections in the cabinet to make sure they are in the correct location and snug. Make sure trigger has continuity when pressed. Check the main contactor to make sure the coil winding has not burned out (unplugged from power source for this check).
Jan 03, 2012 | Welding Tools
Lincoln Electric Mig Welder-Fuse question
dont know what unit your uncle has but here is a easy test,open unit go to feed motor unplg the connector have unit running pull gun trigger check for voltage at plug ,if no voltage trace wires back (with the unit unplug , for your safety)probably will go to one side of main contactor.restart unit being careful for this is main input power.if no power main contactor is bad .if you have power at motor plug(wire feed motor) the motor is bad. hope this helps your uncle.
Jul 11, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Oct 29, 2008 | Clarke Power Products Welding Tools
Campbell hausfeld gasless 80a mig welder not working, just quit
there should be a fuse located in the back of the unit near the ppower chord. i would check this keep me posted
Sep 17, 2008 | Welding Tools
Welding Tools Logo
54 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
