Question about Ryobi Talon Trimmer Brushcutter Primer Bulb
Talon chain saw 35cc 14inch ac3100 - Ryobi Talon Trimmer Brushcutter Primer Bulb
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
Replace chain
Do you know that chains can be resharpened? I suggest you find a shop that services chain saws and have it sharpened. If you want to replace the chain a good shop can get you one or make one.
Oct 31, 2013 | Poulan 1420 14Inch 20 HP Electric Chain...
What is the ratio for a 1635a 16" 35cc 2 cycle gas powered chainsaw
a really good guess would be 40-1 not knowing mak
of saw . he owners manualt
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
HOW TO MEASURE CHAIN LENGTH ON SAW
It usually is on the bar. Or in the model number (MCC1635AK) typically means 16" chain, 35cc engine. Taking the chain off and while still in a loop, stretch it out and you will find a 16" should be about 18-19" long.
May 25, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Brake not releasing 14inch ryobisaw
First try cleaning it. Begin by removing the spark plug wire. Then remove the housing and inspect the chain break for broken chain brake parts such as the spring. If all appears intact clean away saw dust, sticks or other debris. Otherwise, the chain break may be simply wore out and need replacing.
Mar 22, 2010 | Garden
Talon AC3100-35cc chainsaw parts for recoil pull start,It is the little plastic peice's that allan keys onto the sprocket?It has a little spring on both of them and it is a main peices as when I pull the...
The part you are after is called a starter pawl, i know because the same thing happened to mine. Unfortunately you can't buy just the pawl, they only sell a flywheel kit which is about $35 which contains the flywheel and two pawls.
Feb 21, 2010 | Talon Electronics - Others
Talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
Sep 21, 2009 | Garden
Ryobi Talon Trimmer Brushcutter Primer Bulb Logo
29 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
