Question about Sony Walkman NWZ-B135 MP3 Player
Driver need driver ,it says boot ,I think it wuz acadentaly formated
Hp dv4-1235ee wireless disable
you can go to control panel and in that go to network connections and there u can see some icons like wireless ,lan and some others also.just double click on it and it will get enabled.if it doesnt works reply ...
Mar 03, 2012 | HP Computers & Internet
How to format pc please show me how
Before you do format your harddrive back up your drivers onto a flash pen or cd first there are free programs on the net to do this. For some reason installing xp to a system you can put money on it you wont have the network driver.
Your going to need an external cdrom as i dont think the ASUS 900 has one? What you need to do is boot from an operating system cd (eg. XP or Win7 or what ever your using) then follow the instructions on screen to guide you through formating and installing of a new operating system.
As i dont know what OS your installing i cant give a step by step guide but the on screen instructions are simple to follow.
Nov 14, 2010 | ASUS Eee PC 900 Notebook
I have an Acer Extensa 4620z, i can't load the OS, i've tried with XP and Win7 and there's an error, i tried to change the setings in BIOS, but there's not any option to change anything about the SATA or...
yes quite right.. when u start the install process I'm sure you noticed that it asked you to press F6 to install any 3rd party RAID / Sata drivers.. these can be downloaded from the manufactures web site..
what concerns me is that windows 7 Ultimate has these drivers built in!!! did u try windows 7 ultimate ???? not the OEM version that ships with systems ,, use a full version..
also DO a full format not a quick format.. when win 7 or xp instillation boots,, delete all partitions and do a full format..
if that fails u need to replace the hardrive,, A dead harddrive will give the same error!!!
Sep 14, 2010 | Computers & Internet
How to reformat a notebook laptop with no CD-driver?
Remove the hard-disk - it will usually connect via an IDE or SATA-compatible interface. You can then connect it to a computer (internally, or via eSata / USB / 1394 enclosure). You can then format it from that computer.
When you say no CD-driver, do you mean Driver or Drive?
if there's no CD drive, it should either have a floppy drive (in which case, any system book disk can re-format the HDD), or USB-booting capabilities.
If there's no driver, than a Windows 2000 / XP CD should be able reformat the disk - when you boot from it, it will load drivers off the CD. You don't need to install Windows normally, the recovery console can format disks.
A Windows 95/98/ME boot disk/CD will allow formatting, but only in FAT/FAT32 file systems (you will probably want NTFS, which 2000 and XP can create)
Sep 05, 2009 | Computers & Internet
I cant find my DSi it wuz in my router then it wuz gone no 1 nose
where was the last time u were with it? or if u have a bro/sis, ask them. sure they would know
Aug 16, 2009 | Video Game Consoles & Games
Need help with toshiba dynabook satellite 1801
Sounds like you may need to re/install or update some drivers.
Attempt to boot the machine into Safe-Mode.
Continuously hitting F8 while booting will get you to the Boot Option Menu.
If you can successfully boot into Safe mode, this may be enough to put things back together.
Attempt Safe-Mode and if successful try a normal boot.
Start from there and let us know the results.
Apr 14, 2009 | Toshiba Satellite A135-S2276 Notebook
I formatted and installed drivers but graphics driver dont work
That is a bummer =( I would try older or different sets of drivers for that video card. You should be able to start in Safe Mode without it crashing, and download and try different drivers.
Typically tapping F8 while the PC is booting, or just past the 1st boot screen will make it boot in to Safe Mode.
Mar 17, 2009 | ASUS Computers & Internet
Dvd drivers are not working
if windows isn't detecting your dvd drive and you think it's because of a virus, check if your bios is detecting it alright. if it is you can just change your boot options to boot from CD and you can format your computer without starting windows.
Dec 19, 2008 | Computers & Internet
Boot hang after formatting of hard drive
no there isnt, you need to take it and put it in another computer as a slave drive. But you might have damaged your hard drive, you can try Hiren's boot cd from here www.phazeddl.com but personally i think you might have messd up the drive.
to install as a slave
1.) find a working computer
2.) put hd in as slave (do not remove old hd)
3.) boot
4.) it will show up in my computer
5.) format and unmount drive
it the computer fails to boot ensure you got the drive connected propperly and jumpers are correct
it thats all good then your drive is damaged
Jan 02, 2008 | ASUS P5GD1-VM Motherboard
Sony Walkman NWZ-B135  MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
