Ir2520 error paper jammed
My machine has displaying the error massege the paper has jammed.
  • 685 Answers
SOURCE: Paper Jam error message
Here's a video that should help...
http://h30460.www3.hp.com/?fr_story=2304f3aa563aa6dbf7a24b8a764d74f1b43314d2&rf=bm&fr_operatingMode=OneSpecificStory
Posted on Aug 03, 2009
jaye_ellen
  • 591 Answers
SOURCE: Displays paper is jammed message when there is no
There must be a bit of paper torn off and stuck in the sensor for the paper jam on the Output side of the printer. Look for a tiny bit of paper where one ought not to be.
Posted on Sep 21, 2009
  • 295 Answers
SOURCE: Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Posted on Oct 20, 2009
supersaiyan1
  • 5 Answers
SOURCE: Canon MX700 - Error msg: Paper Output Slot - Paper
1) Is there a way you can check if there is paper jammed other than looking in the front of the printer, maby the rear or bottom prehaps?
2) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
3) Contact your printers manufacturers website.
Posted on Nov 07, 2009
supersaiyan1
  • 5 Answers
SOURCE: Canon MX700 - Error - Paper Output Slot - Paper
Try this link:
Paper jam error displays - there are no jammed papers - cant get it to print
Check paper path for bits of paper, or jammed/damaged sensors. only takes a little bit of paper to jam a sensor, then make sure it is reset, even turn off for a few minutes.
Jul 29, 2014 | HP LaserJet Enterprise M602x Printer
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
HP 3030 error message paper jam - clear papaer path. There is no paper in the machine. I have cleared and cleaned the machine, turned it off, waited 30 secondsand turnedit back on and still get the error...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 29, 2011 | HP LaserJet 3030 All-In-One Printer
Paper jam .what to do.
No, a switch actuator is trapped down or has been knocked out of it's mount.
Jun 01, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Our customer has a Canon Laser fax L800, Error message of Jammed paper displays, despite the fact that there is no paper jammed in the machine, paper path looks ok. Any ideas !!
Is it a jam or an add paper message (same light)? Sometimes you have to press the start button after you add paper on this machine.
Nov 27, 2008 | Office Equipment & Supplies
23 people viewed this question
jasbo
jasbo
