Question about Hardware & Accessories
I have a brinks ez dial timer type 42-1006 and I have no idea how to set it
5 Suggested Answers
SOURCE: I bought brinks ez dial
Smart thinking using wall timer instead of buying new coffee pot.
I'll remember that tip.
I test timers.
A lot of timers arrive defective, and other stop working short while later.
Some last for many years.
On your timer, make sure slide switch is pushed all the way over to TIMER or TIMER ON.
Plug regular lamp into timer, turn lamp ON, and manually rotate timer dial clockwise to see if timer trippers will turn lamp ON-and-OFF.
If timer functions with manual rotation, then see if dial rotates on it's own.
The dial should rotate, or else timer is defective.
If dial rotates, and timer works for lamp, then double check that your coffee pot is ON at all times.
The timer just opens the circuit to coffee pot, but coffee pot has to be ON.
Also take advantage of fixya phone support for any type of problem.
For a price, fixya expert talks to you over phone to resolve repair issues.
Posted on Jan 01, 2011
SOURCE: I have a brinks 44-1030
Manual is shown on links below:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 19, 2011
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 02, 2011
  • 5245 Answers
SOURCE: Setting brinks ez 42-1006 timer
1) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
2) Use link above to Experiment with features
Posted on Dec 16, 2012
Dec 14, 2012 | Hampton Technologies Brinks Timer
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
Hardware & Accessories Logo
301 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
