Question about Intel Computers & Internet
Compatible. Processor "I3-2120" and GA B75M D3H motherboard. Is this fully compatible?
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 36 Answers
Look for appropriate classificational proccessor mehn.
Don't act dump.
Posted on May 08, 2013
  • 23 Answers
SOURCE: gigabyte mother board
hi reason y it wouldn't start is because the 2 is not compatible, what u can do is get a Intel P4 not a celeronD check the socket size and make sure that it correspond with the board that u have. The board that u have uses a 478 socket size so u need to get a processor with the same socket size ok... that should do the trick
Posted on Dec 01, 2007
shaky120
  • 310 Answers
SOURCE: are they compatible?
Hi, your cpu currently in the machine should be a 754chipset, only way you would be able to put a core duo processor in the machine would be to replace the motherboard, cpu, and probably the memory.. to DDR2
Have a good new year
John
Posted on Dec 29, 2007
DickCanFixIt
  • 948 Answers
SOURCE: Hard Disk Drive compatible with AMD Athlon XP 1700+ with Gigabyte
All IDE hard disks are compatible with those items.
Posted on Feb 21, 2009
knatcal
  • 53 Answers
SOURCE: compatible upgrade processor for intel pentium
The E5200 would be a nice upgrade. It retails on Newegg.com for 65-69.00 and usually has free shipping. And if you have a compatible motherboard and purchase a nice heatsink, it overclocks very nicely.
Posted on Aug 27, 2009
joecoolvette
  • 5660 Answers
SOURCE: Can the sSpec number affect the compatibility with my motherboard or not?
While both processors operate at a Frequency Rate of 3.8GHz, (3800MHz), and have a FSB of 800MHz,
the SL8PY uses the R0 stepping, (R-Zero), and the SL7Z3 uses the N0 stepping. (N-Zero)
[FSB = Front Side Bus]
Apparently the Northbridge of the motherboard chipset, won't support the R0 stepping.
[Northbridge for Intel is called the MCH, or IMC.
Memory Controller Hub, and Integrated Memory Controller, respectively]
The 'Motherboard Chipset' is the Northbridge/Southbridge chipset.
'Chipset' is a slang term for IC. Integrated Circuit.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Stepping is a design change to the same model of processor. There may be a few stepping changes, or many. (A0, B0, C0, Do, A1, A2, A3, B1, B2, B3, and so on) Just depends on what the engineers come up with, before the next model comes out.
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Yes, I also checked Intel Support for the Intel D915PGN motherboard, and supported processors. I did not see a BIOS update for using a SL8PY processor either, in the Downloads section.
Posted on Sep 02, 2009
Gigabyte ga-f2a88xm-d3h won't boot, The fans come on, the drives spin up, but no post or video output. There is no power to the mouse or keyboard. Using 500 w PS as reccomended by manual.
Sounds like a voltage regulator has failed on the board. Check the capacitors in the power area are not raised on the tops. Check all the voltage outputs are present from the power supply.
Apr 05, 2014 | Gigabyte GA-F2A88XM-D3H Desktop...
GA-H77M-D3H 6 beeps on POST and then restarts
Check timing between each beep---Make sure It's 6 Even beeps--Not 3+3--1+5--2+4 ect----Timing between beeps will tell you---let me know.
Mar 01, 2014 | Gigabyte GA-H77M-D3H Socket 1155/ Intel...
Motherboard + processor compatibility
Yes you can use the processor on your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Dec 23, 2013 | Gigabyte GA-8S661FXM-775 (4719331838096)...
Intel E5500 processor compatible?
Here is a compatibility list: Compatibility list Gigabyte GA-8s661fxm
The E4500 which is very similar, just slower clock speed is supported. I cant guarantee it would work, but I'd make a bet in the favor of yes.
How do iconnect a huntkey max 600 w to gigabyte ga-b75m-d3h motherboard
simply place the 20/24 pin power plug into the power socket on the motherboard.
Nov 20, 2013 | Gigabyte Computers & Internet
What kind of graphic i install that support my motherboard GA-B75M-D3V
go to boards web site download support that will let you know ok
Aug 17, 2013 | Computers & Internet
Installing processor chip
Do you need help with installing it?
Here's a video guide with how to install the processor onto your board assuming you already bought the processor :) As long as the processor is made for Socket-H it will do.
http://www.youtube.com/watch?v=H_QVWBm4CI4
Feb 26, 2013 | Gigabyte GA-Z77MX-D3H Intel 7 Series...
I want to find out if this motherboard is combatible with ddr2 memory and if i can upgrade the processor to dual core
Type: Dual Channel DDR 400/333 Mhz
Max capacity: 4 GB
DIMM slots: 4
Use Socket 775 processors:
Supports LGA775 Intel® 90nm Pentium® 4 processor FSB800 with HT technology
Apr 15, 2009 | Gigabyte GA-8I915P Duo Pro Motherboard
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
Computers & Internet Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
