Question about Samsung DVD-R155
Stopped running Driving down the highway bike cut out. Would not restart. Checked 20 amp fuse,ok recharged battery, checked oil. Engine turns over but will not start
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
Why won't a toyota engine start
Have you checked all the main engine fuses?
Aug 14, 2014 | Cars & Trucks
I have a 99 Ford escort zx2 and it only does it occasionally, but if I'm going on a highway at 65 MPH, it wants to slow down and only go around 50 MPH. Sometimes the wheel locks up and service engine...
Sounds like a week fuel pump have the pressure checked at a local repair shop. Also if it has a lot of miles on it the catalytic converter could be stopped up also have the local shop check it out it is real easy to check.
May 19, 2013 | Cars & Trucks
Went to start, engine cranked slightly and then all power was lost. Fuses ok
If the fuel pump is not delivering adequate fuel pressure and volume to the engine, the engine may not start or run properly. Low fuel pressure can cause hard starting, a rough idle, misfiring, hesitation and stalling. No fuel pressure will prevent the engine from starting, or will cause the engine to quit running if the fuel pump fails while driving.
Fuel injected engines are very sensitive to fuel pressure as well as fuel volume. Low pressure will cause starting and driveability problems. A pump that can deliver adequate pressure but not enough volume may allow the engine to start and idle normally, but it will starve the engine for fuel and cause a loss of power when the engine is under load, accelerating hard or cruising at highway speeds.
Jul 28, 2012 | 1999 Honda VF 750 C Magna
I just bought my 2003 PT Cruiser and was driving it home about 30 mins about buying it and driving it home on the highway as I was getting off the freeway and making a right hand turn the whole car just...
Does anything happen when you try to start it? Do you get any clicking noises or any noises at all? Does it matter whether you have it in neutral or park when you try? It could be that your alternator has stopped charging, either because the belt broke or came off, or because it's faulty. Have you tried recharging the battery or starting it with a boost from another car?
Feb 22, 2011 | 2001 Chrysler PT Cruiser
Engine cut out at highway spped & won't restart
Check the starter relay. Everything you're talking about gets it's power through there on the earlier bikes.
Jul 20, 2010 | 2004 Harley Davidson FLHTCUI Electra Glide...
My 1983 honda vt500c has GAS in the oil not water just gas any ideals as to what the problem could be? bike will still run.
I would add the following thoughts for consideration. Many things can cause this, some are, from a short driving cycle that doesn't allow the engine to fully warm up, to a faulty fuel pressure regulator, to leaking fuel injector/s or a carburator float bowl being overfilled, to worn engine parts, like piston rings, valve guides, faulty spark plugs resulting in poor fuel burn ect, ect. Basically it's gasoline getting from the top of the engine, into the bottom of the engine, where the oil sump is. Gasoline in the oil isn't good for it, or the engine, as it dilutes the oil & robs it of it's lubricating properties, resulting in accelerated engine wear & bad engine deposits. Best to change the oil & filter right away, review all the listed ideas & have the most likely checked out by a pro you trust. If your bikes mechanical condition is ok, but your driving cycle is short, after changing the oil & filter, try changing your driving cycle, or by taking your bike on a weekly 20 mile interstate round trip, to warm the engine & oil up competely, to evaporate condensation & any gasoline thats found it's way into the crankcase oil sump. Your ride will love you for it & the gas oder in the oil, will likely take a hike!!!! your bike is not good mechanically or u would not be getting fuel in oil. take it to a REPUTABLE mechanic and get it looked at .problem may be small and easy to fix. the longer you wait the worse it will get
Jan 17, 2010 | Honda VT 500 C Motorcycles
Cuts off, but will restart, then cuts off again
Likely, you have a damaged engine bearing. When there is a problem there it will turn oil pressure light on because bearings keep the pressure inside the crankshaft...It may stop as the bearing overheats and binds, then loosens up a bit allowing a re-start when it gets cooler. Battery sounding dead is likely because the engine is locking up and too difficult for starter to turn.
At this point, it is not a do-it -yourself project ...either you need a lower end rebuild or engine replacement.
May 28, 2009 | 2004 Jeep Liberty
Fan cooling
Doesnt sound like anything out of the ordinary.  The only things you can do to help remedy that more is run synthetic oil get a right hand side air scoop or cut vents into your undertail panel.,,
Nov 10, 2008 | 2007 Buell XB12X Ulysses
Samsung DVD-R155 Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
