Question about Philips MC-90 CD Shelf System
Low volume hi my philips mc 90 when playing cd the put the volume on max it sounds like it's the volume is on one radio sounds ok it's not on mute
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
Posted on Apr 08, 2008
jdvillanueva
  • 2098 Answers
SOURCE: My Philips DCM230 home stereo
Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
Posted on Jan 05, 2011
  • 6771 Answers
SOURCE: Sound distortion on medium volume with radio, cd, aux, ect.
The problem is in the audio driver or output stage which is normally an ic semiconductor, it is recommended that a technician look at the stereo to assess cost.
Posted on Sep 25, 2012
Low volume on radio, I replaced the amplifier with an used one, but the problem still present. All channels are Ok.
When you tried play a cd and you got low volume with amp, 1. Try find a original cd and plays it see if the sound loud or low if it's still low you need lenses disc cleaner, to clean your decks lense.
Oct 15, 2013 | 2004 Acura TL
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
Xtreme Sound WMS336 CD PLAYER NO SOUND CAN YOU HELP ME THANKS
im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
Feb 13, 2011 | Xtreme Sound WMS336 CD Player
Max volume is way too low
what causes that issue is that your treble and bass are probably turned all the way down. just adjust those up to max and your unit will be alot louder.
Jul 18, 2009 | Bosch PB10-CD Radio/CD Boombox
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
I have a 1999 Chevrolet Suburban with the factory radio. The radio works fine but when I put in a cd and turn the volume up some, it just stops playing for about 20 sec. It will come back on at a very low...
sounds like your popping the breaker, after a while your speakers will go, theres just too much power for it to handle, take it to a car audio store and get them to test it, you may need new speakers
Jun 20, 2009 | Car Audio & Video
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Dec 15, 2007 | Philips HTS3440/37 System
Very Low sound
Make sure none of the tape monitor switches are on as this is a typical symptom when one or more of the tape monitor switches are active.
Sep 27, 2006 | Pioneer IS-22CD CD Shelf System
Philips MC-90 CD Shelf System Logo
14 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
