Lg wd 10481tp
How to tub bearing replacing
2 Suggested Answers
  • 67 Answers
SOURCE: How to replace bearings on LG WD-1019BD washer?
To get to the bearings you need to remove the rotor as you have done, remove the front, you need to push a card under the lip of the top at the front to open the top to get out the front. Then then you need to undo all the bolts in the middle of the tub, then take out the inner drum and then you can hit the bearings out with a drift, Don't just replace the bearings, you also need to replace the seal and spider which is the 3 legged part with the main shaft on it, otherwise if you don't replace all the parts listed it will not last long before the same happens again. The problem is caused by the seal letting watter into the bearings, the new seals are mdified to help stop this happening.
Posted on Apr 17, 2010
WD-8050FH, LG Intellowasher washing machine, front door gasket is twisted. What is the likely cause?
Broken spyder. The three arm hub that attaches to the inner tub. It is replaceable. Open door and wiggle inner tub. If it moves inside of outer tub, that's a sure sign.
Oct 01, 2017 | LG Washing Machines
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
How do i change the tub bearing on a LG front load washer?
Unless you are a skilled DIY person, I do not recommend that you try to replace this tub bearing on the washer yourself. One has to virtually strip the entire machine to remove the tub to accomplish this bearing replacement.
If you are skilled, then please supply the model number of your machine.
Oct 11, 2014 | LG WM Washing Machines
Apr 12, 2009 | Washing Machines
Replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Dec 02, 2008 | LG WM-1832C Front Load Washer
Removing the bearings from my direct drive washing machine
If you're talking about the rear drum support bearing, they are usually not removable. They are molded into the plastic tub shell. When the bearings go bad you generally have to replace the entire back shell of the wash tub.
May 22, 2007 | LG WD-1280FHD Front Load Washer
Removal of the bearings
Those bearings are almost impossible to remove.  You would be better off replace the rear half of the tub assembly as it comes with everything.
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
