Question about Garden
Crf50 07 model, blows a fair bit of smoke and the kick start gets stuck and you have to pull I back up. It was left for 6 months with out riding. Any ideas on what to do???
5 Suggested Answers
harlan301
  • 205 Answers
SOURCE: my T1760 blows white smoke for 60 sec when starting
it could be your choke stuck, but check you oil level and smell it does it smell like fuel. if so have your carb check out. Little lube on the chock lever. you may want to have your compression check and a leak down test done.
Posted on Oct 11, 2009
  • 18 Answers
You have to check for a coolant leak into the cumbustion chamber. This unit is liquid cooled. Check coolant level and check head bolts for torque
Posted on Apr 25, 2010
  • 640 Answers
SOURCE: I have a 1970 simplicity
You are going to have to remove the recoil starter to see why it is hanging up. May have to deassemble to repair, or replace.
Posted on Jul 14, 2011
  • 6468 Answers
SOURCE: husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Posted on Apr 30, 2012
My kickstarter gets stuck on my 1985 honda xl350r, when i put bike in gear and pull backwards it releases the kickstarter but when i try to kick it gets stuck after 1 or few kicks any ideas?
Very cool!
This bike is 30 years old.
There will be worn parts.
My suggestion...........
Dismantle the kickstart components, and check every part as you do so, looking for worn gears, sloppy bushings, and binding parts.
Fix the bits, put it back together, and ride on.
Cheerfuls!
Jun 30, 2015 | Honda Motorcycles
Yamaha ag 200 monocross
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. WHITE SMOKE on start-up can is usually caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers.
2. BLUE SMOKE on start-up is usually caused by failed valve seals. Smoke that is constant while riding is usually caused by valve to guide and piston ring clearances that have exceeded service wear limits.
3. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://mybikemanuals.com/yamaha/yamaha-ag-owners-manuals
OEM parts for Yamaha
https://app.box.com/s/udl8cy7wtauah94q1nn66z9hciy7f9ub
Blaster slugish and blowing white smoke
AG200 Central everything about the Yamaha AG200 motorcycle
Nov 14, 2013 | Yamaha Motorcycles
I hv activa for 2006 model,my daily travel is almost 50 kms perday - 6days in a week, from last 6 months Activa started giving starting problem and last week white smoke started coming out while drivi
White smoke is classic head gasket problems in water cooled engines ... Your engine is air cooled but you can still have top end troubles. I suggest you have your motorcycle checked by a professional before you ride much more. info on your ride here: http://www.honda2wheelersindia.com/activa/specifications.html
Dec 03, 2012 | 2005 Honda Activa
Husqvarna mower losing power
i will try to help... is it a hydro or geared hydro has a release on the back of the rider if the fluid is low then this can slip kick and make it seem like the trans axle is going out if its geared then they could be rounded off and causing you to stop slowly and not pull a hill
Oct 02, 2012 | Husqvarna Garden
While riding my Suz GS500F (2009) home in the rain last night I started seeing smoke coming from the lower left side of the motorcycle. Stopped at a light and loads of smoke came up through the fairing....
I presume that you were riding it back from the dealer when you had the smoke problem ?? in that case one possible cause could be that when they serviced it they got some oil on the exhaust pipe and when the pipe got hot it burned it off. let me know if that helps or not. Alex.
May 19, 2011 | 2009 Suzuki GS500F
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
My T1760 blows white smoke for 60 sec when starting
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Honda XR200R won't start unless push-started and rattles.
Hello kstnflip360,
I'm not 'expert" when it comes to motorcycles, however, I know that a "clink" or "rattle" (especially on a small engine such as a dirt bike); could only mean one thing - a bent, loose, or broken push rod, or connecting rod. Again, I'm not expert, but that's what it sounds like to me. I can't really think of anything else inside a motorcycle engine that would make a sound like that. The best way to find out is to take the engine apart and take a look-see.
Sorry I can't tell you exactly what it is. As far as the smoking, you may have had a little water in the oil - or the fuel mixture was off. If the fuel mixture is too rich, the engine will burn hotter than it should which will cause it to shut down. Chainsaws work the same way.
It is imperative that the fuel mixture is correct, and that you're using fresh fuel.
Thank you for choosing fixya.com
carsandcomps
Guru, fixya.com
Oregon
Apr 13, 2009 | Honda Civic Cars & Trucks
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
