Where can I find information on the Sharp SF 8200 copier? How old is it, does it do color, etc...
  • 1,326 Answers
A Sharp SF-8200 is a black and white analog copier. It is very, very , very old.... At least 15 years old or more... I would use it as a anchor for a boat. But that is only my opinion.. Run Forest run...
Posted on May 08, 2013
  • Kage Nienhuser Jun 08, 2013
    Thanks! you saved me!
  • 163 Answers
SOURCE: sf-1118
plese write c interrup 0 interrupt 50 copy key 1 copy key,select c and then adjust registration by changing figures
Posted on Sep 23, 2007
CopierITWiz
  • 14 Answers
SOURCE: sharp sf-2540 copier f1-00 code.
If your machine has a sorter it may be caused by the wiring harness that goes to the sorter from the machine being pinched. Try powering down the machine and unplugging the sorter and powering the machine on. If your problem goes away it is a sorter issue if not it may be a problem in the fuser.
Posted on Jan 17, 2008
  • 4 Answers
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Posted on May 30, 2008
  • 990 Answers
SOURCE: Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Posted on Oct 01, 2009
  • 257 Answers
SOURCE: H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Posted on Oct 31, 2009
WHAT CAUSES THE FREEZING OF THE PANEL WHISLT ENTRIN' SIMULATION
Ar-Al models are digital .ar-m some models with color scan.SF models are old and analog.
May 06, 2010 | Sharp AR-M205 Copier
Full black
Check copy lamp if its lighting during copying if not Switch off and remove socket outlet and check lamp and thermal fuse . Clean optics.
Sep 21, 2009 | Sharp SF 2020 Copier
Not working due to error
Unfortunately, a U3 is a LSU motor issue. You will need a Authorized Sharp Service Agent to inspect your machine.
Aug 17, 2009 | Office Equipment & Supplies
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
Apr 02, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
Feb 10, 2009 | Sharp SF 2020 Copier
Sharp sf 2530 hang
I would suggest to throw that old thing in to a pond see if it will float..
Oct 24, 2008 | Sharp SF 2540 Copier
79 people viewed this question
jasbo
jasbo
