There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st
button light blink rapidly = the printer may be out of paper, so load
more paper and press the 1st button itself to continue. Or may be paper
jam is occur, so clear the paper jam and press the 1st button light
itself to continue.
If 1st button light blink slowly = mean the
cartridge carriers are stuck, so raise the scanner unit and remove any
object blocking the path of the cartridge carrier, make sure the
cartridge are closed and installed properly, then lift the scanner
unit, gently push the scanner support towards the cartridge carriers,
and carefully lower the scanner unit until it is completely closed.
After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (
